Low oil pressure
Old May 22, 2006 | 11:45 AM
CudaMan's Avatar
CudaMan
Low oil pressure
Pulled a load from LA to TX,(14,000lbs @70), with no problems, but noticed the next day the oil pressure stays low and erractic. Had the oil changed(didn't need it), but I am getting worried why oil pressure is low. Not the first load this truck has seen. Hopefully guages, any ideas, main bearings? (186,000 mi.).
Old May 22, 2006 | 11:52 AM
CudaMan's Avatar
CudaMan
Oil pressure
By the way, had oil changed last month and all they had was Delo 400. Don't much like it as I prefer the Rotella. Any preferrences. I did have it changed back to Rotella this time.
Old May 22, 2006 | 12:14 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Stock Gauge or Aftermarket? The stock gauges are NOT accurate. They send a signal to the PCM as the pressure changes and the PCM decides what signal to send to the gauge. After market gauges will give you a more accurate reading. Possibly a bad sending unit? Possibly an oil pump starting to go or worn mains? First step is to have it checked with a mechanical gauge to give you a true reading.
Old May 22, 2006 | 12:24 PM
Ron McCafferty's Avatar
Ron McCafferty
I prefer the Rotella in any diesel. Especially my own. But the difference in oil pressure should not change with different brands. First thing I would do is have the oil pressure checked with a good gauge. Sound like you use yours for work. And you don't want to put an engine in it. At least if you check with a gauge you will elimate one or the other.
Have you been using Motorcraft filters? They have a built in check valve. Check the pressure first that way you can rule out a pump or bearing problem. Gauges are much cheaper to fix.
Old May 22, 2006 | 12:32 PM
CudaMan's Avatar
CudaMan
Yep, I work it hard, but I also keep 'er in good shape. It does have stock gauges. I plan on putting a mech. gauge as I never trusted that sucker anyway !
bohinny
Jul 8, 2019 09:44 PM
Derrrrick
Oct 22, 2015 10:46 PM
cliffordthetruck
Mar 5, 2004 06:44 PM
rebocardo
Sep 30, 2002 06:53 AM
gilatrader
Jan 23, 2002 02:33 PM
