Single Barrel Carb
Old Mar 22, 2002 | 04:39 PM
69slow's Avatar
69slow
Single Barrel Carb
I just inherited/purchased a 69 f100 w/ 300 for my grandfather's estate. It is stock to the bone and he has cared for it his whole life so it is my first and strongest remeberance of him.
He has made few changes that I see except the carb, trans, and tires. I had new kingpins replaced so I could drive it 18 hours home from Oregon and now it drives like a porsche compared to my Bronco. It also has a three speed with AOD (if it wasn't for this,the truck probably wouldn't break 50 mph) on the floor with the remains of a column shift.
Now I am home at sea level and I am having problems with the carb. I already adjusted the air idle adjustment which seemed to tune it up but then I shot a good portion of carb cleaner into the carb while running and it hasn't been the same since.
It runs fine for the first few seconds but as soon as it warms, and I apply gas it floods. I can get it to move only by pumping the gas pedal and the choke completely on but it won't idle like this. I also replaced the decomposing vacuum advance hoses before any of this problem arose (passed the three way split with spring vacuum unit located off bock above valve cove and went straight to the diaphram off of the distributor. also plugged remaining line port on carb).
What could it be and why would the carb actually run best without any air coming through the carb at all? Could the cleaner have actualy clogged a jet? What adjustments should be made beside the air idle intake and idel adjust?
I can see some fuel being shot in when the linkage is fully open but don't know if it is the right quantity. I am a carb novice and have only dealt with fuel injection if you can beleive that. I looked for a rebuild kit but there are no numbers and it only says FoMoCo engraved in the side (Ford Motor Company). All my local shops are confused and already gave me two incorrect rebuild kits.
I am just looking to get the truck to Reno 6 (hours) where I can swap the carb, intake, and headers which are waiting for me. I need to make it over Donner pass going faster than 35 though and the gas milage could hurt my wallet as well. Can anyone battle this one?:-staun
Old Mar 22, 2002 | 04:50 PM
Mil1ion's Avatar
Mil1ion
Single Barrel Carb
What altitude differential has taken place.
From what to Sea level?
Were the idle air screws adjusted?
Was the timing changed?
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
[font color=blue]Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [font/]
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Mar 22, 2002 | 05:26 PM
69slow's Avatar
69slow
Single Barrel Carb
Sea Level change from Portland ???? to Sea Level.
No timing has been changed but I did tinker with the iel air adjustment. It lacked power before I adjusted the ai idle adjust. Then it ran good until vacuum lines and carb cleaner.
Perhaps I will reinstall the little vacuum line splice and then screw with the carb. What can I screw with on the carb?
Old Mar 23, 2002 | 07:10 AM
jestertatt's Avatar
jestertatt
Single Barrel Carb
Your carb should be a Carter single barrell carb. I am no expert but I was able to find good rebuild info in the Chiltons Truck Repair Manual 1961-1971. The rebuild kits are cheap, and I was able to rebuild mine (first carb rebuild attempt for me also) in about an hour. The fine tuning took several test drives, but all in all not too bad. Hope this helped, Good Luck.
Old Mar 23, 2002 | 07:49 AM
jowilker's Avatar
jowilker
Single Barrel Carb
brooklyn
26
Nov 9, 2023 11:21 AM
mrmauser303
21
Apr 23, 2016 02:41 PM
spltend
Jan 21, 2015 12:21 PM
DoesItReallyMatter?
85
Apr 23, 2014 07:32 AM
moonshine34
Jun 9, 2013 09:23 AM
