hooker aero chamber mufflers
Old May 26, 2006 | 07:09 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Spintechs drone a lot less than Flows, sound and flow better also.
The drone at least with the 4 1/2" size exhaust I have at the end is between 14 and 1,700 rpms, once above that or 40 mph it's totally silent in the cab.
Going thru a parking garage is fun hloding 1,600 rpm's as the drone reflects off the ceiling, floor and walls, sets them car alarms off or hold throttle at the drone zone next to a getto blasting POS car, electric cut outs work best at that on a friends 513" Ford.
I'm going to add a pair of Vibrant's stainless steel resonators (part # 1141) as I have elderly neighbors, that ain't right to not respect your own neighbors.
Are you going to add a "H" or better yet a "X" crossover pipe? They lower the Db's besides help scavenge if you run a "X" cross with headers.
.....=o&o>.....
Old May 26, 2006 | 09:09 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
im just running a single 3" pipe....i dont see the point of duals on a stock truck
same thing with my big truck...i run dual 3" into a 4 pipe then down into a 3.5" pipe and into a moroso spiral flow muffler, sounds awesome with 10:1 compression and 472 cubes
Diamnd1
Aug 26, 2016 08:28 PM
Colorado Highboy
Mar 23, 2016 10:22 AM
cjben
Sep 17, 2015 04:02 PM
benross71
78
Feb 3, 2015 08:22 AM
pbear6969
47
Sep 7, 2007 01:21 AM
