I have a 79 F-150 with a 351M. I removed the mufflers and replaced them with straight pipe it sounds good, not too loud at idle but has a nice rumble when I rev it up. I heard that removing the mufflers can burn valves. Can this cause too little backpressure and burn valves or will it be ok like this?
thanks for any opinions on this.
backpresure is bad, the myth about burning valves because of strait pipes is from running open manifolds or someting very short and the cold air rushes in after running for a short time and it hurts the exhaust valves, running straight pipes wont hurt anything but your ears
Does it have cats on it? If not then you will want mufflers. You won't burn the valves in it unless you're running no exhaust manifolds at all. The only forseeable problem is that yo're going to lose some torque, and may have trouble getting a load to move off the line. I'd put a nice set of mufflers on it and call it good. Straight pipes are illegal in most states due to noise laws.
It has hedmen headers and cats but there bored out.I had stock mufflers and tried glasspacks. I'm not trying to make it loud and annoying just trying to give it alittle bit of a rumble and make it sound like a V-8. right now it sounds like a newer truck with a stock exhaust.
I had a 1979 F-150 with a 400, same exhaust setup as yours, minus the cats. I agree you will be fine, the cats will help keep it a little quieter than mine was.
