EGR Valve
Old May 21, 2006 | 12:19 AM
birddogs462's Avatar
birddogs462
EGR Valve
I have a 2005 F-250. What is the benefit of disconnecting the EGR valve.
Old May 21, 2006 | 04:49 AM
kw5413's Avatar
kw5413
With Ford's EGR strategy thru reflashes and an upgraded (?) EGR Valve...the immediate benefit is not realized on the '05 / '06 as it was on the '03 / '04 engine builds.
The newer strategy keeps the little bugger closed much more now than with previous strategies.
The downside is...it is still a WART. When open it still dumps trash into your already sensitive high tech system potentially presenting a negative effect on down stream components. In addition, when...not if...the EGR Valve sticks open a plethora of ill effects take place.
IMPO: With possible exception to the RMS leaks, the EGR Valve is arguably the single highest warranty hit Ford has taken with this engine.
But, it has performed so well that it is rumored that there will be multiple EGR Valves on the 6.4....
06FUN
Oct 29, 2016 07:53 AM
Bayou Burt
Aug 5, 2011 06:30 PM
Xscutout
Feb 24, 2011 09:10 AM
JTS RIDE
Aug 24, 2010 06:33 PM
USMC Diesel
May 10, 2007 12:31 PM
