Vibration at 2000 rpms when accelerating?
Old May 20, 2006 | 06:30 PM
swanee's Avatar
swanee
My 2006 now has about 2500 miles on it and have recently noticed vibration or shutter on moderate to heavy accelaration. It happens briefly as the needle sweeps past 2000 rpms and is more pronounced the harder you accelerate. I noticed this only now because I probably have been going easy on the truck until recently, breaking in and such. I do not remember this behavior in my 04, but my memory might be failing me. Any thoughts, thanks.
Old May 20, 2006 | 07:34 PM
vloney's Avatar
vloney
there has been known issues with vibrations taking off from a stop. That one says driveline angle is too steep. Put shims in the driveshaft carrier bearing(no more than 3). that one happens at 1500-2000 rpms
Old May 20, 2006 | 07:59 PM
swanee's Avatar
swanee
That's interesting, I think the vibration is coming from the engine, but then again I could be wrong.
Old May 31, 2006 | 08:14 PM
bilder12's Avatar
bilder12
does this thing seem like it will jerk you out of the seat if you stay at it ? Got 2 6.0's in the neighborhood that are making drinkers out of us. They will not do it all the time only when they want to and at cruise or accelaration. Both have been in the shop and cant seem to fix the problem. Almost like fuel is shutting off or boost is being diverted ... what say you all?
Old Jun 1, 2006 | 07:12 PM
Sunny NM's Avatar
Sunny NM
I just experienced the exact same symptoms. However, in my case it was caused by an injector, gone bad.
Old Jun 1, 2006 | 09:01 PM
'Ol Timer's Avatar
'Ol Timer
I have the same problem with my '06 with 1500 miles, especially during moderate accelleration. It is also really bad at a constant +-45 mph on a smooth road. Going back to the dealer next week.
Old Jun 2, 2006 | 01:05 AM
Sunny NM's Avatar
Sunny NM
I should have mentioned in my post, I knew about the injector from my Superchip diagnostic. It took the local dealership two days to figure it out and now, after it had been replaced, everything runs smooth as ever again. I have now 6K miles on the truck.
Old Jun 2, 2006 | 05:17 AM
ceopi's Avatar
ceopi
<TABLE border=0><TBODY><TR><TD width=230>FORD:
</TD><TD>1999-2006 F-Super Duty</TD></TR></TBODY></TABLE>
This article supersedes TSB 04-22-7 to update the vehicle model years. ISSUE:
Some 1999-2006 F-Super Duty vehicles may exhibit excessive drive-away shudder or vibration, under moderate to heavy acceleration from a stop. This may be due to driveline angle.
ACTION:
Shim the center carrier bracket downward to correct the condition. Refer to the following Service Procedure.
SERVICE PROCEDURE
When shimming the center carrier bracket, a maximum of three (3) 1/4" shims may be used (EOTZ-4A209-A). When refastening the carrier bracket use bolt (56564-S2). A 7/16 x 14 grade 5 bolt may be substituted providing that it extends at least three (3) threads past the nut. Use Motorcraft Threadlock 262 (TA-26), and torque bolts to 46 lb-ft (62 N-m).
<TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>IF THE VEHICLE IS NORMALLY LOADED, ROAD TESTS WILL NEED TO BE PERFORMED WITH THE VEHICLE LOADED.</TD></TR></TBODY></TABLE>
  1. Before beginning the repair, road test the vehicle to gain a feel for the harshness of the shudder/vibration.
  2. Install one (1) shim, (DO NOT use Threadlock on the bolts at this point), re-road test vehicle.
    1. If condition is corrected, apply Threadlock and torque bolts as directed above.
    2. If condition is not corrected, re-perform Step 2 (to a maximum of three (3) shims) and reevaluate vehicle.
      <TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>IF THE CONDITION IS STILL NOT CORRECTED AFTER INSTALLING A MAXIMUM OF THREE (3) SHIMS, REFER TO WORKSHOP MANUAL SECTION 205-00 FOR FURTHER DIAGNOSTICS.</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH align=middle>PART NUMBER</TH><TH align=middle>PART NAME</TH></TR><TR><TD class=NOBOTTOMBORDER align=left>EOTZ-4A209-A</TD><TD class=NOBOTTOMBORDER align=left>Shim</TD></TR><TR><TD class=NOBORDER align=left>56564-S2</TD><TD class=NOBORDER align=left>Bolt</TD></TR><TR><TD class=NOBORDER align=left>TA-26</TD><TD class=NOBORDER align=left>Threadlock 262 Motorcraft</TD></TR></TBODY></TABLE>
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH align=middle>OPERATION</TH><TH align=middle>DESCRIPTION</TH><TH align=middle>TIME</TH></TR><TR><TD class=NOBOTTOMBORDER align=left>051706A</TD><TD class=NOBOTTOMBORDER align=left>1999-2006 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair (Includes Time To Raise Vehicle And Install Threadlock)</TD><TD class=NOBOTTOMBORDER align=left>1.2 Hrs.</TD><TR><TD class=NOBORDER align=left>051706B</TD><TD class=NOBORDER align=left>1999-2006 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock)</TD><TD class=NOBORDER align=left>1.7 Hrs.</TD><TR><TD class=NOBORDER align=left>051706C</TD><TD class=NOBORDER align=left>1999-2006 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair, Install A Second Shim And Road Test Condition Still Exists, Install A Third Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock)</TD><TD class=NOBORDER align=left>2.2 Hrs.</TD></TR></TBODY></TABLE>
DEALER CODING
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH align=middle>BASIC PART NO.</TH><TH align=middle>CONDITION CODE</TH></TR><TR><TD class=NOBOTTOMBORDER align=middle>4A209</TD><TD class=NOBOTTOMBORDER align=middle>42</TD></TR></TBODY></TABLE><!-- google_ad_section_end --><!-- End Content -->
andres0517
Jun 27, 2013 05:23 PM
milkman00
Modular V8 (4.6L, 5.4L)
Jan 17, 2009 12:06 PM
rebel70754
3.8 & 4.2L V6
Dec 30, 2008 06:15 AM
speedworks
Jan 5, 2008 08:45 PM
01 PSD
20
Mar 1, 2006 06:45 AM
