Posted in electrical, too
Old Mar 29, 2002 | 07:47 PM
jds1971's Avatar
jds1971
1971 F100 360 w/C6
I don't have tachometer. Is it possible to take a reading from the coil (neg. post) using a digital multimeter that measures frequency? Or do ya'll think it will fry the multimeter?
Old Mar 29, 2002 | 11:16 PM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 30-Mar-02 AT 00:17 AM (EST)]No!
You need a tach.
Maybe if you have a 20,000 Volts setting it might work.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3180&.jpg
http://www.geocities.com/asphaltcowboybob//index.html?1017459313540
http://community.webshots.com/user/mil1ion
[font color=green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Mar 30, 2002 | 09:34 AM
jds1971's Avatar
jds1971
This will not hurt your meter There is a max voltage range for reading frequency.Check the instructions.You will have to divide by the number of cylinders to convert to R.P.M.
Larry
The above was posted in the other conference by Larry. It makes sense because we will be looking at frequency, not voltage.
Do you mean that there is 20,000 volts on the neg. post of the coil? I thought that was going to the cap via the coil wire.
Old Mar 30, 2002 | 11:07 AM
Mil1ion's Avatar
Mil1ion
You're correct,I miss read it.
I'm bad.
http://www.clubfte.com/users/mil1ion/index.html
Old Mar 30, 2002 | 07:18 PM
jowilker's Avatar
jowilker
Old Mar 30, 2002 | 07:21 PM
lshort's Avatar
lshort
I went out and got my digital multimeter and tried this on my truck
and it does work.Except to get to R.P.M. first you have to get to
hertz (times per second)meters usually read khz.Then multiply times 60
(to get to times per minute)then divide by the number of cylinders.Also not sure of the accuracy of this as digital frequency counters are very sensitive and will count
electronic "noise" as a pulse.May have to do some input conditioning
to make it accurate.Let me know if you are interested in this.It can be done with a few componets.It would be intersting to compare it to
a tacometer as meter may work ok.Also you can use a annalog meter for a tacometer.
Larry
Old Mar 31, 2002 | 04:44 PM
jds1971's Avatar
jds1971
[updated:LAST EDITED ON 31-Mar-02 AT 05:46 PM (EST)]Excellent point, Larry-
I tested my theory also and came up with fairly accurate results. After all calculations, I concluded that my engine was turning ~825 RPM. That sounds about right as I always thought it was running a little fast.
Now, according to my manual for the multimeter (Greenlee DM-500), it has a built in line filter that can be set to 50 HZ or 60HZ to reject unwanted noise. Set to 60HZ, I believe the measurement to be very accurate. What do you think?
Joe
Old Mar 31, 2002 | 06:30 PM
lshort's Avatar
lshort
I think you now have a tacometer.
Larry
josephbrenner
22
Jun 17, 2015 02:47 PM
texas2fst
May 15, 2015 09:09 AM
JAFO1
Oct 4, 2008 10:10 AM
385seriesHemi
Mar 25, 2006 07:02 AM
jds1971
Electrical Systems/Wiring
Mar 30, 2002 08:44 PM
