Why Would My 6.9 Do This?
Old May 19, 2006 | 10:19 PM
sams6.9's Avatar
sams6.9
at idle if you push the timing advance rod in on the drivers side of the injection pump on my truck why does the diesel clatter go away? I have alway heard that it is supposed to make it stumble. This one has me stumped, because it does not stumble it just quiets down. Also it does this if i run it up to 2000 - 2500 RPM and push the rod in. Thanks for the help.
Old May 21, 2006 | 12:00 PM
PLC7.3's Avatar
PLC7.3
When and how was the timing last set, just a guess but it may be off time and the reaction is different.
Old May 22, 2006 | 09:53 AM
sams6.9's Avatar
sams6.9
timing has never been touched. its the original ip
Old May 22, 2006 | 07:58 PM
bilder12's Avatar
bilder12
if you havent been using a fuel lube type additive, you may be having the advance piston gawled from lack of sulfur content in the fuel and wont move properly.
Old May 23, 2006 | 10:26 PM
sams6.9's Avatar
sams6.9
I use a additive every fourth tank. But it is going to shop in the morning (kinda scared about putting it in someone elses hands) cuz i got to have this truck for work.
