96 F350 CC (4 door) Power locks won't unlock. Changed both switches. pass side will lock all doors but neither will unlock. Disconnected all 4 actuators 1 at a time, still no go.
Getting frustrated. 14V at all plugs at actuators. was getting 3-4v on lock side or unlock side and 14 on other, till I disconnected front pass side actuator, now 14V & 0V (must have bad actuator on that one) could they all be bad???
Both rear doors are now connected and they lock no problem, still wont unlock.
Both switches give 14V when pressed to lock or unlock.
Thanks for the wiring diagram Franklin2. It turns out that a wire going to the alarm (inside the boot in the door jamb) had come disconnected from the cheap bullet connector that the alarm installer used. Simple problem, easy fix. All it took was 6-7 hours of diagnosis, and now my arms look like I was playing with a gator (lot of sharps inside doors). Again thanks, without diagram, never would of figured it out.
Your welcome, I thought that the wiring diagram would help that I sent you.
