Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape V6 engine light on
Old May 19, 2006 | 08:38 PM
00GT's Avatar
00GT
The little orange engine light came on 2 days ago, so i had autozone hook it up to there scanner and he said it had to do with the egr He unpluged it before i could see the code. I'll have to take it back tomorrow and re-hook it up for the code. It has 113,000 miles on it if anyone needs to know. Anything common?
Old May 19, 2006 | 09:26 PM
Racerguy's Avatar
Racerguy
Chances are pretty good that the code is a P0401 and you'll need a new DPFE sensor to fix it.
Don't let them sell you an EGR valve without some diagnosis. They seem to like to sell those.
I'd get the new DPFE at your dealer as Ford has come out with a new improved part.
Old May 20, 2006 | 05:01 PM
00GT's Avatar
00GT
Thanks for the reply...but what is a DPFE sensor?
Jimmy
Old May 20, 2006 | 05:34 PM
ove1's Avatar
ove1
Here's a thread with a diagram and explanation. Search is your friend.
https://www.ford-trucks.com/forums/s...highlight=dpfe
rockauto.com lists an aftermarket part for under $25.
Old May 21, 2006 | 07:51 PM
00GT's Avatar
00GT
I had autozone put the scanner back on and sure enough, the code is P0401
Thanks for the help, I'll get the part and let you know what happens
Old May 25, 2006 | 10:47 AM
00GT's Avatar
00GT
Thumbs up update
I replaced the DPFE sensor and fixed the problem. Ford dealer wants $52.00 bucks and i got it from rockauto for 33.00 shipped.
Thanks for all the help!
Old Jun 3, 2006 | 11:08 PM
00GT's Avatar
00GT
Update!
check engine back on!! Had to autozone and the same code came up P0401 I orderd a egr and it should be here tomorrow. I'll put it on and keep you people updated.
Old Jun 4, 2006 | 12:58 PM
AlfredB1979's Avatar
AlfredB1979
You are doing the same thing AGAIN without diagnosis.
PLEASE! DO NOT fall for the temptation of swapping out parts on a whim or you will become frustrated AND lighter in the wallet.
Old Jun 4, 2006 | 01:51 PM
00GT's Avatar
00GT
I was told and i have also read if it pulls the P0401 code it could be only two things. DPFE sensor or the EGR . I did the cheaper one first and it didnt work. If the EGR dont work either......well then, i dont know.
Old Jun 4, 2006 | 03:54 PM
ove1's Avatar
ove1
The EGR valve is vacuum-controlled by a solenoid. Maybe the solenoid is sticking or there is a leak in the associated vacuum hoses. This is the first case I've heard of where it wasn't the DPFE causing a P0401 or P0402 fault. I hope that you didn't get a bad replacement.
Old Jun 4, 2006 | 08:06 PM
00GT's Avatar
00GT
I was driving today and the light went off by itself. Its been off all day now and i've driven about 60miles. What could this be? I picked up the EGR today also from a/z but i havent put it on yet. Do you think i should return it?
Thanks for the replys
Old Jun 5, 2006 | 01:01 PM
ove1's Avatar
ove1
I don't know what Autozones return policy is, but I wouldn't install the EGR valve if the light went out. Keep it for a few days and if your fault light doesn't come back on, return it before the return period expires. Do you experience any driveability issues when the light comes on? If you don't, I would guess that it is a false fault caused by an erroneous DPFE output. Make sure that the electrical connector fits tightly and that the contacts are clean. It wouldn't hurt to put a little dielectric grease on the contacts as well.
Old Jan 5, 2008 | 05:00 PM
MPDano's Avatar
MPDano
Is this the one you are talking about at Rockauto?
STANDARD MOTOR PRODUCTS Part # VP17 {EGR VALVE POSITION SENSOR}
EGR Pressure Feedback Sensor
2001 FORD ESCAPE 3.0L 182cid V6 FI (1) : Emission : EGR Pressure Feedback Sensor
Old May 20, 2013 | 08:39 PM
melissar's Avatar
melissar
i seem to be having very similar problems with same model escape but my code p1409 this has to do with egr soleniond i replaced it and the iac valve and many vacum lines i also clean the dpfe sensor but the code wont go away help
Old May 20, 2013 | 09:30 PM
projectSHO89's Avatar
projectSHO89
Please do not
1) Hijack/resurrect old threads without good reason and an explanation
2) Post the same thing in multiple threads.
One post in the most appropriate place will get the job done. You already have a new thread...
