I was looking up the name of the color of my truck and found the codes on the sticker. The codes read First: SN Second: Z3 which is Silver Metallic. The truck is a tow-tone. The truck has the nicest blue I have ever seen. One of the biggest reason I bought it. Then the silver on the bottom. But when I looked up the code for the blue (SN) on the specs page in this forum it did not have the code SN. I checked the stick two more times because I thought I was going nuts but it really is printed SN. Does anybody have any idea why and what is the name of the color of my truck. I would really like to know. The truck is a 2003 F250SD Larait. Any info would help. Thanks Michael
Where did you find the "sticker with the code on it on your truck, I have basicly the same truck (and by the sounds of it the same colour) but I'd still like to know where the sticker is, or where it's supposed to be.
Thank
Mike
Penner857,the sticker is located on the inside right hand side driver door pillar. In my case with the truck being a extented cab its on the driver side rear door on the outer edge were both doors come together. Hope this makes sense. , Michael
Ok thanks, I finally found mine on the center piller of the drivers side door at the bottom, Mines a Super cab (4 full size doors) but by the sound of it both your's and mine are the same color SN and Z3
