The product you mention might work but I think it leaves much more to chance.
"Tailgate must be removed for installation so have an assistant on hand. Two 3/8 inch holes need to be drilled. One in the inside corner pocket of the 1/4 panel and one in the bottom of the tailgate. Install time, 20 to 30 minutes. Tools needed: tape measure, power drill, 3/8 drill bit, eye protection and marking pencil."
With the EZDown you do not remove the gate or drill holes... I think the extra money is worth not screwing up your gate.
With the EZDown you do not remove the gate or drill holes... I think the extra money is worth not screwing up your gate."
I think in my 60 some odd years, I've learned how to drill 2 holes and I've already removed my tailgate without extra help. I think I'd just as soon save the 40 bucks.
I think it was on the stylin concept website and they have a kit so you can open your hard cover pluse put down your tailgate all with a push of a single button. I'll see if i can find a link.
Not exactly. Tailgates can be heavy and you have to put some muscle into it in order for it to lower slowly. Due to the torsion bar's weightlessness, there is no effort involved to have to make it lower slowly.
Neighbor has one installed on his pick-up. Works great....feels like a very light tailgate, but is original.
I do not think you can drop the tailgate with torsion bar as you can with the ezdown. I like the idea of being able to let go of the tailgate after unlatching it...
