Offroad & 4x4
Need Some Help!!!
Old May 19, 2006 | 11:49 AM
300-6's Avatar
300-6
Talking Need Some Help!!!
I ahve an 87 f150 4x4 , this weekend I am going to repalce the front wheel bearings, This is my first time on a ford. I am wondering does the ford front axle have the wheel nut with "teeth" or is it a plain nut. Any idea on the size also?
Old May 19, 2006 | 12:49 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
shoudl be a ttb dana 44, it will have a nut with slots for a socket with "teeth", you should be able to pick up the socket you need at any parts store, just ge tone for a dana 44
Old May 19, 2006 | 12:55 PM
74fordtruck's Avatar
74fordtruck
You can try to rent the "spindle nut socket" from a parts store, I know we rent em for $6/day. I ended up buying one though (even though i could rent it for free ) just cause i use it enough, and its more convenient that way. I think they're around $20
Old May 19, 2006 | 01:26 PM
300-6's Avatar
300-6
Okay Thanks, I have called around they all seem to say just bring the nut in with and match it up, That makes a lot sense!!!!!!! Good help is just hard to find
Old May 20, 2006 | 08:14 AM
Jmudder79's Avatar
Jmudder79
So you asked them for the socket to remove the spindle nuts and they told you to bring the nut in to match it up? Did you mention to them that you need the socket to remove the nut in the first place? It's also possible to remove the nuts with a screwdriver and a hammer. Just put the screwdriver in one of the slots and tap it counterclockwise to loosen it. That method tends to chew up the nut a little, but it would be a good way to get one off to bring down to match up with the socket.
Old May 20, 2006 | 02:34 PM
BroncoRoadKill's Avatar
BroncoRoadKill
It's a standard socket made for all D44 front axles, ford solid and ttb and the ones of older GM trucks.
Snuggyworm
Feb 6, 2015 11:17 PM
BURNSTOUGHFORD
Apr 5, 2011 12:02 AM
Scott81FORD
Mar 30, 2009 09:48 PM
mr_muldoon
Mar 30, 2005 05:35 PM
JTD1972
Feb 5, 2005 02:55 PM
