Trans - No OD ??
Old May 19, 2006 | 06:30 AM
mackatack's Avatar
mackatack
Trans - No OD ??
My 2000 PS (60k miles) will not go into 4th/OD. Telltale on the shifter does not illuminate or function. Otherwise seems fine: No hard shifts, fluid level fine and looks/smells right.
Appreciate any insights here....hate to go straight to the stealership. Thanks in advance!
Old May 19, 2006 | 07:30 AM
Kwikkordead's Avatar
Kwikkordead
Check the wiring harness inside the shift column. Many posts about how it rubs through and frays.
Old May 23, 2006 | 06:50 AM
mackatack's Avatar
mackatack
Thank You !!
That was it. Poor design....3 tiny wires bundled, and restrained so they fatigue as the column tilts. All 3 were broken!! 45 minute repair and all is well.
Thanks again, much appreciated!!!
Old May 23, 2006 | 07:23 AM
PSNut's Avatar
PSNut
The Stealership would probably have replaced your trany AFTER they found the wiring problem.
Old May 23, 2006 | 08:58 AM
TiogaKid's Avatar
TiogaKid
Dumb Question
How do you access these wires to check?
Old May 23, 2006 | 09:12 AM
mackatack's Avatar
mackatack
Not too bad
Remove lower column shroud...3 screws. Remove top shroud...have to pop off black key cylinder cover with a screw drive. Wire comes out of the shift lever and on mine (2000) is taped black.
If you have to repair, be careful, very small wires. I used a lighter to heat and then stripped wire covers with my finger nails. I did not put the wire back into a routing clip they have there...figured would give it more room to flex and hopefully not break again. Reinstall shrouds in reverse.
Note: The key chime (key left in, door open) is a bit tough to put back in. I simply taped the end of mine and did not reconnect...hate the thing anyway.
Good luck...easy repair....could do it in 20 minutes if I had to again.
Old May 23, 2006 | 09:15 AM
TiogaKid's Avatar
TiogaKid
Thanks
Thanks for the quick answer. I'll go check mine.
Old May 23, 2006 | 12:51 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Yeah, if they can get a transmission rebuild out of you they will. It's all in the name of making a buck.
Old May 23, 2006 | 08:50 PM
Betthebux's Avatar
Betthebux
If the wires are not repairable you can get a new lever with wiring for just under 50 bucks from the stealer. I cut the key in chime wire (black with pink tracer, I think) while I was there. Much better now.
