Custom Intake Pics
Old May 18, 2006 | 01:39 PM
sauced1173's Avatar
sauced1173
Custom Intake Pics
Does anyone have some good pics of a custom intake they have for their 7.3l turbo diesel??? I really want to make one for mine and was looking for ideas for some inspiration...its kind of tight there by the radiator to get something in there with any gurth...any tips tricks or suggestions would be more than welcome, and obviously pics!!! thanks
Old May 18, 2006 | 04:59 PM
MartelBrothers's Avatar
MartelBrothers
Spectre makes the pieces to make up a custom intake kit. The tubing is a 3". They even offer a mockup kit for $10 with a $10 mail-in rebate when you purchase the pieces and filter to make a system. Here is a link -
http://martelbrothers.com/catalog/Sp...t-p-16039.html
Old May 18, 2006 | 05:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
https://www.ford-trucks.com/user_gal...100545&width=2
https://www.ford-trucks.com/user_gal...100511&width=2
I built this for about 20 dollars and a Saturday afternoon.
40 sq. in. front scoop
4" diameter hose
Works well.
https://www.ford-trucks.com/user_gal...7&albumid=6980
I have about 300 dollars in this exhaust, it also works well.
Old May 18, 2006 | 09:25 PM
DeepRoots's Avatar
DeepRoots
you're so fancy dave with your stove pipe and all....
I used abs drainpipe I happened to have laying around (obviously the type without holes in it).
that and 10 min with my sawzall, and it made a pretty good difference, especially in the egt dept.
I prefered the drain pipe because I can yank it out in 5seconds to work on something.
Old May 18, 2006 | 10:22 PM
Dave Sponaugle
Two screws and everything under the hood is out on mine well.
Plus when I am plowing snow or driving in heavy snow, I just disconnect the stock flex line and I am good to go in 30 seconds time.
PS; that is not stove pipe, it is galvanized HVAC duct work.
I also noticed my EGT dropped about 200 degrees. I have to stay in it fairly hard with a fair sized load to get to 1200 degrees now. A big hill and a big load and it will still get hot enough I have to start backing out though. Plus my turbo don't suck the filter restriction gauge near as bad as it used to.
Old May 19, 2006 | 01:01 PM
sauced1173's Avatar
sauced1173
thanks
thanks a lot got, definatly got some good ideas to work with now...specially love the dual stacks, however i am not looking to do something like that cause i have a good bed and tool box, i am thinkin more along the lines of a 4" single...i need to get a 3" down pipe too...what did you do to get the cool air draw, i mean what did you ahve to do to the rad support brackets to fit that large intake there???
Old May 19, 2006 | 01:22 PM
1978fordf250's Avatar
1978fordf250
hey dave i noticed on the truck there is 2 areas where the coresuppost is reinforced like 2legs running up the core suppost. Now I was wodnering did you cut the hole for your scoop to run between them? also how wide and how high is the front of your scoop where the air enters in.
thanks,
Jimmy
Old May 19, 2006 | 01:41 PM
1978fordf250
ok after lookign really close to your setup it looks to me like you cut the core support wqhere the radiator mounts to the coresupport on the driverside. am i correct? If so what holds the radiator in on that side? I am tryang to do that all to a 1993 with the 7.3
Old May 19, 2006 | 04:15 PM
Dave Sponaugle
I took the drivers side radiator support off and file 13ed it.
Then I took a 4" grinder with a cut off wheel on it and trimmed the radiator flange off on the outside and inside, but left the top mounting hole.
Then I used 1/4" x 1" x about 4" piece of flat strap iron to make a new support coming down from the top of the radiator shell.
Holds the radiator very well, you will never get your truck in twists and binds like I get mine in every day. I have had no trouble in about 4 years since I did mine.
The front of the scoop is 4" wide and 10.5" tall, but reduces to 3" x 9" to go through the radiator shell by the radiator.
Then I took a 6" round vent pipe about one foot long over to the anvil with a couple of hammers and a set of metal tongs and aviation snips.
After a little argument with the pipe, which I won because I had a bigger hammer, the pipe is now 6" round on one end and 3" x 9" rectangular on the other end. The rectangular end is also cut on an angle so it clears the power steering pump pulley when I slide the 6" round to 4" round reducer over the pipe.
Then a 4" single wall adjustable ell slides over the reducer on the small end, it is almost straight the way I have it twisted.
The stock 4" flex duct then slides over the ell and onto the air cleaner.
The front scoop is made out of one piece of furnace plenum flat stock, a bunch of cuts and a hand full of pop rivits.
I looked at all my furnace duct supply catalogs trying to find a premade scoop, but nothing is close to what it needs to be.
I have my radiator shell out laying on the ground right now and everything is apart. If it ever stops raining I will take some pictures of all the pieces and how it goes together.
Since it is all apart, I may even see if I can come up with a better design while the engine machine work is being done. If it ever stops raining, 8 days of rain so far and I can do nothing to my engine till it stops.
93f250tn
Oct 26, 2009 11:44 AM
jim6liter
May 22, 2008 09:48 AM
1977f250
23
Dec 18, 2005 07:45 PM
fordeverpower
Jul 31, 2005 11:03 PM
duketter
Apr 18, 2002 03:53 PM
