which power steering box is which?
Am I being to vague?
Thanks Robert P.
A slipper type will leak early with a full time pump set up and a full time will chatter when used with the slipper type pump.
If your truck is 69 or later & OEM Stock, it should be the newer slipper type P/S sys.
FBp
The Bendix steering gearbox requires the full time non-slipper type pump. The Bendix gearbox can be identified with an aluminum top cover, held down by 4 bolts.
The fulltime pump is always a steel cannister type, with a dipstick in a narrow fill tube.
The Bendix box was used '65 - '69, possibly into early '70.
Note that the two types of gearboxes were used roughly '69 - '70, so you need to pay attention to which type you have.
The only other type of power steering gearbox used '69 - '79 was the Ford or Saginaw box.
It can be identified as having a steel top cover with only 2 bolts. Up to '76, it
it also used a cannister type pump, but with the slipper type internal mechanism. In other words, a cannister type pump CAN BE a slipper type which looks identical externally to the non-slipper type.
The later plastic wide-mouth pumps, and the flat pancake style pumps (looks sorta like GM pumps) are all slipper type. I have found that in most cases, a round plastic case pump bolts up in place of the round metal cannister one. You will need to get a pressure hose for it though, as the outlet fitting is different. As for a pump and a pressure hose for a '78 F-150 with a 351M, and you will get the correct application.
Hope this helps!
OK, now that I have new info, let me now get to the point.
71 crew f250 2wd.Whichsetup would be best - Pump and gear box. Don't forget about me running an inline filter.
Thanks.
