99 Expedition Tailgate Info/problem...
Old May 18, 2006 | 12:40 AM
kc8zti's Avatar
kc8zti
Hi, I've got a 99 Expedition, which is having an issue with the door ajar light staying on along with my interior light. I've read the WD40 comments and will try that, I know that latch is rusty looking so it may fix it. If it doesn't, how do you get the tailgate panel off? The wiper won't work, its striped or something on the tailgate so I'm going to need to get in and check that out, might as well take care of both issues. I've not found anything on here to explain how to get the panel off on that model. Its a 99 Eddie Bauer Expedition. Thanks!
Old May 18, 2006 | 01:21 PM
luxury's Avatar
luxury
Your problems may be related. If the rear window sensor is the one causing the door ajar warning, it will also disable the rear wiper (to prevent it from running with the window open. I would try to lube up the rear window latch before you go after the wiper motor. If you can hear the wiper motor trying to work, then you have a different problem - it may be as easy as tightening the nut that attaches the wiper arm to the motor (this is a common problem with the front wipers).
Old May 18, 2006 | 01:52 PM
idbl_fanatic's Avatar
idbl_fanatic
If it is like my 01, there are 1 screws on the handle that you use to pull the gate down, take those out, and then take the panel from around the window (it pulls off) and then the lower panel also pulls off, you can pull it out a little bit, and see the fastners in there, what I do is get a pair of needle nose pliars and put the on each side of the fastner and pry it up.
Old May 18, 2006 | 02:31 PM
kc8zti's Avatar
kc8zti
They're not related. The wiper problem was long before the door ajar issue. At first it would not work, I'd grab the wiper arm and move it up and it would work fine. Sometimes it did this, sometimes it didn't, but that always got it to work. One time I pushed a little to hard, and it stripped it. If I push it up when its on it will go across, then come back down and stay there. You can hear a grinding sound. I'm assuming its junk, but want to pull it apart and find out why, and possibly replace it if needed.
Old May 21, 2006 | 01:55 AM
kc8zti's Avatar
kc8zti
Well, it was the switch. The WD40 thing didn't work for me, however I unplugged the harness now my lights will go off! I'll get a new switch sometime soon, that whole thing was corroded and rusted up pretty good. For 2 years I had a salt spreader on the back of it, which could be why. Though I wasn't using salt, anyhow I appreciate all the help! I was able to get the panel off, though I didn't check my wiper issue out, I will later now that I know how easy that panel comes off. Once again thanks.
Tim
Old Jun 1, 2006 | 12:25 PM
jmwcctx's Avatar
jmwcctx
OK, I"m new--what's the WD 40 info? I've got the same issue...Thanks.
Old Jun 1, 2006 | 08:38 PM
TDN's Avatar
TDN
If the dome light stays on and the "door ajar" light is constantly lit on the dash, you probably have the same issue. Just spray a bunch of WD40 into all the door release latches (really soak em) -- that's it. Works for most people (including me on my previous truck, a 97 F150). At least for a while anyway.
Old Jun 2, 2006 | 02:07 AM
jmwcctx's Avatar
jmwcctx
Thanks so much! Geez, about 10 more posts and I should have a practically new Expedition (or is it "expy?")
Old Sep 1, 2024 | 01:56 PM
Jcards's Avatar
Jcards
7th Gear
99 for expedition do you spray the wd 40 from the inside after removing the panel or directly into the latch. Can someone tell me how to disable the running board lights and the interior lights when the back window is closed but the lights are still coming on when parked. Waiting for rear window hinges to arrive since one of them is broken
1999er
Jul 24, 2014 05:27 PM
jgfan24
Aug 5, 2011 10:19 AM
papadelogan
Dec 14, 2009 10:09 AM
lakesidebluexpy
Aug 17, 2007 07:08 PM
ranger4by
1983 - 2012 Ranger & B-Series
Sep 21, 2003 02:07 PM
