Any luck having your friend put an '07 through with the V10 in New Jersey? I called a dealer and he told me F-350 only and no truck before July 1 for whatever reason?
Crazy,
How are you holding up? Are you just dying to get your hands on this truck?
no as i have not been in touch with anyone more then doctors. the past week plus. the jerk that did my neck screwed up big time and is causing me go though it all over again.
the guy screwed up so bad i have to go to a university hospital for a super specailist that does only spine repair failures . and before you ask yes i have a lawyer.
i'll try getting ahold of eric this week to see what hes found .
Hey Blue,I was down our camp site for 4 days.I was away from the computer.Yes ,I can't wait already,it's been about 2 1/2 weeks since I put my down payment at the dealers.I havn't heard any good news,or bad news,but I'll keep you in touch.Hey Charlie , sorry to hear about your problem.I have to go for a emg,because of herniated discs in my neck.I hope they could feed me pills instead of a operation.
just got back from the ford dealer,just put my down payment on my 2007 f250 V10 lariat.Let's see how long it takes FORD now.
Diesel are the only way to go. What is so great about a V10. You guys must not pull any thing out there. You guys should come out to the midwest and we will show how to use a real pickup with power.
Man did you really want your first ever FTE post to be a lame bunch of crap like that?
Search through WrenchTravler. CaptChas, and Fredvon4 extensive five years of debating gas vs OIL for a lot of ideas on how to get under our skin... this was a weak attempt at being a troll and I am ashamed for you.
Check out all the diesel forums for your support group... I hear they are having a get together to cry about the 6.4L diesel option costing above $8400 next year
I can tell you don't even have a clue about the Triton V10 so I won't waste my time other then to ask you to move on... and shake my head that a fellow Ford truck owner could be so narrow minded..
MAN don't come down here and start the smoker lover Bs. one word for guys like you =TROLL!!!! stay up in 6.0 or 7.3 land and leave us that know a lot better about how gassers have pulled the loads longer then you are alive. and as to pulling my bet is my 05 v10 stays right with you on a big grade with 2 race cars inside the inclosed toy hauler 5er. and the west side of new jersey is full of big long ones so i know first hand how it pulls
i'll bust my but to help any body out with a problem here in fte just don't start off with your very first post trolling down here with us mature men and ladies
good luck crazy the test is long and some shots are painfull big time. my problem the first doc screwed up and won't admite it . c 5-6 and c6-7 are not doing any thing the fusing failed .the plate is not even screwed in correctly . i've lost the use of my left arm no feeling at all.
i truely hope p.t. and pills work for you
my prayers go to you.
WELCOME to FTE!
With that out of the way... DO NOT come down here and start this garbage.
You've been warned.
Me thinks this is a troll who got out from under his bridge for the first time since 1996. Pre-V10, that is...
Question... when I wrote the flame for the PSD troll the 'puter redirected the post several hours ago and to me it was lost and did not appear. I shrugged it off as not worth my time to re-write
Now it is here but with one section missing... did the machine edit me or did you?
and either way what in it got it flagged? (I know why it was edited, just trying to figure out how it happened the way it did) I have not read the rules in years so skool me if I did a no-no
Hello, I have just signed up for this forum thing so I hope I'm doing this right. I have a 99 E-350 V-10, this is obviously why I joined. Thanks for the MPG chart you guys did, thats the first question out of the way allready. I'm getting 13 in town, not sure of the hiway numbers yet because I'm still tinkering with things. I'm sure you know there are very few aftermarket parts for the "E" series so I have to make most things myself. I am putting the finishing touches on a cold air box and an intake that dosen't have to make 3 90 degree turns. It seams to have helped alot but as I said still not done. The exhaust was the other thing, 1 24inch Gibson offset muffler, 1 smaller muffler, a custom made Y pipe and 2 resonators later, I can finally drive without sounding like a clapped out V 6. Flow is good, much better than stock. The van is stock except for taking out all the bench seats but one and building a wall dividing the passenger area from the tool and materials area. Oh, I forgot to mention 138K on the odometer. Thanks for all the info, I'll look foward to watching what others have to say about these motors. I think they are great.
PS: My Dad has an 03, all the same.
Must be a higher power around here... if you want, I can bring it up with the "gods that be" - and I probably will.
Once in a while, I got the "moderated" message, maybe 3 times total. Each time, it could have been questionable tactics (to put it lightly) or a certain website that I linked to. Once, I went back, editted out a link I had in there, and it was not really a link, more like "go to aaa dot com". I removed it, and reposted, and voila! it went right through.
I think there is a "semantics" filter running here, that if you get into a certain pattern, your message gets sent to someone to look at. Usually, I would be notified I'd think, but if they were busy enough it can fall through the cracks.
I have no info directly about something like that.
It might have been a language filter thing, as in you intentionally tried to get around it, or used some other phrase that triggered it. Or, there's some glitch where your message got stuffed somewhere, some wizard (Ken) get it out of there, read it, editted it, and sent it on it's way.
