stock wheel
Old May 17, 2006 | 03:26 PM
mopnup's Avatar
mopnup
stock wheel
I have an 03 PSD 4x4. I am considering adding a procomp lift upsizing tires. My questions are;
1. Is the Pro comp lift of if I am using on street 95% of the time. And how much lift do I need to go to a 35 inch tire?
2. What size tire can i fit on the stock wheel if I do the lift?
3. What is the largest tire I can fit on my stock rim with no lift?
I did a search and got some of the answers. But the only other lift I purchased was a Donahoe for my f250. Very nice but I think more than i need on my Ex.
Thank you for your help in advance.
Old May 17, 2006 | 04:00 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I can only answer a few of these questions as I'm not too familiar with lifts.
305/70/16, I'm not sure but if it's the biggest size, but this is what my neighbor has on his lifted '04 right now.
Probably about 285/75/16, but since you have 4wd, you could probably squeeze some 295s on there without a problem.
Old May 17, 2006 | 07:16 PM
cficare's Avatar
cficare
When I bought my 305-70R16 tires, the tire labels said 16x8 rims minimum. The stock wheels are 16x7.
Old May 18, 2006 | 07:52 AM
Downsized2X's Avatar
Downsized2X
Diesel User
Also the 285/75/16 call out for a 16x7.5 min sized rim. There are alot of X's out there with them and I planned on getting them for my next set. My tire place will install them without question.
I believe that I will need to have the dealer update the ABS system for the new tire size.
Old May 18, 2006 | 09:36 AM
Toreador_Diesel
He had those 305s on his stock rims, I remember driving up to look at them and I saw 305/70/16.
