steering box removal ?
Old May 17, 2006 | 02:10 PM
just2dune's Avatar
just2dune
I have a 1996 f250 4x4 and I need to replace the worn steering box. My question is does the steering shaft just pull out of the top of the box or does the shaft have some kind of snap ring or something holding it into the steering box. Thanks for any help I did a search and could not find anything.
Old May 17, 2006 | 03:04 PM
1997F-350's Avatar
1997F-350
if you pull the plastic cover back down where the shaft and box meet. there is a connector. it has a couple bolts. i was looking at mine a few weeks ago. i plan to replace mine with a unit from RED HEAD STEERING GEARS. how about you?
Old May 17, 2006 | 05:48 PM
tjbeggs's Avatar
tjbeggs
there is a pinch bolt that must be removed as it clamps and slides into a cut out grove in the gear box shaft.
