1978 - 1996 Big Bronco
how much $ for 100HP?
Old May 17, 2006 | 12:44 PM
69ford99's Avatar
69ford99
I was wondering what would be the cheapest way for an extra 100hp out of a 5.8L? I found a powerdyne supercharger that says 45-50% increase in power for around $2500. Could I get about 100 more horsepower from a new intake and heads? The edelbrock performer heads and upper and lower intake run about $1900, I could throw in some ceramic headers and make it to $2500.
Old May 17, 2006 | 03:16 PM
blackened's Avatar
blackened
im not sure how much power a good set of heads and intake will put out along with headers, but im sure all three together would put out around 100 more. if youre gonna get those go with a bigger cam and MAF, have the computer tuned. i dont know if it can be or not.
Old May 17, 2006 | 03:29 PM
Kemicalburns's Avatar
Kemicalburns
a kennebell is a better truck SC because it builds torque right off idle vs 2000+ rpms like most other SC. but to gain the full bennys of an sc you really need to have heads,intake,bigger throttlebody, headers and a free flowing exhaust to begin with. the stock setup will be choked out. I suggest you start with those pieces and see where your at, get comfortable with it and go from there. when you think about going with a SC you have to also keep the compression ratio below 9.0-1 otherwise you will have head gasket issues
Old May 17, 2006 | 08:59 PM
ctch88's Avatar
ctch88
What about building up the drivetrain? I don't think the stock tranny will take many miles with a SC, although I have heard of it being done before.
Old May 18, 2006 | 09:49 AM
Kemicalburns
depends, if it has a good tranny cooler and is well maintained it will probably hold up. but you do make a good point that the tranny and a few other components will need addressed to handle said power increase.
Old May 18, 2006 | 02:05 PM
masseysbronco's Avatar
masseysbronco
If he's gentle with it until the upgrades to the drivetrain can take place he should be ok. Won't be able to enjoy the new power though.
Old May 18, 2006 | 02:25 PM
BillyBob69's Avatar
BillyBob69
Just take it easy from a stop. Once moving down the road, you should be able to play with stomping it without all the torque blasting your stock drivetrain.
Old May 19, 2006 | 10:09 AM
69ford99's Avatar
69ford99
I planned on getting a shift kit for the tranny, so that should help a little right?
Old May 19, 2006 | 10:16 AM
69ford99's Avatar
69ford99
Does anyone know if a aftermarket maf is worth the money, and what about a bigger throttle body?
Old May 19, 2006 | 10:47 AM
Kemicalburns
a shift kit helps with shifting, but does nothing to increase the strength of a tranny. infact it may cause increased heat which KILLs an auto tranny quick. only go with MAF if you absolutly need to. speed density can handle a cam,head,intake,throttlebody upgrades no problem. the key is getting a cam with a lobe seperation no less then 114*. compcams can help there. BBK has a 56mm throttlebody that is direct bolt on , may or maynot give an increase depending on the rest of the stuff done to motor including exhaust being stock or upgraded to headers and free flowing y pipe/muffler
Old May 19, 2006 | 12:43 PM
69ford99's Avatar
69ford99
My bronco is a '96 so it has a maf, and I have the bassani y pipe with a mandrel bent tailpipe, but still have stock manifolds.
Old May 19, 2006 | 02:44 PM
Kemicalburns
ok, well being its a 96 we are dealing with obd-II setup here. therefor custom tuning will be required for most any major mod you perform. Headers would complement your exhaust big time, look into a ceramic coated header to reduce underhood temps.
Old May 19, 2006 | 11:59 PM
69ford99's Avatar
69ford99
So headers would give me more noticeable power than I got with just the y-pipe? Oh and it wouldn't make it too much louder will it, I have an original 40 flowmaster and its louder than my stereo and I have a 10" sub in the back.
Old May 20, 2006 | 06:06 PM
Encho's Avatar
Encho
The Southernmost Mod
Yes, upgrading the exhaust system is the best way to gain some easy, cost effective HP rigth away, there are various kits around, i´m looking at a Pace-setter´s (around a 12-14.5% HP gain).
