pinion angle
Old May 17, 2006 | 12:38 AM
tgowers's Avatar
tgowers
pinion angle
i am about ready to lower my 68 f100 ranger.... going to notch the rear frame section and flip the rear end on top of the leaf springs and add lowering blocks.... what is the proper pinion angle for the rear end and drive shaft? i don't want to start throwing drive shafts out behind me as i'm cruising down the highway. any information is good information. thanks guys.
-tony
Old May 17, 2006 | 01:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
http://www.drivetrain.com/driveline_angle_problem.html
There are all sorts of links to good info in the links section of my home page.
Old May 17, 2006 | 07:35 AM
BobbyFord's Avatar
BobbyFord
Here's some similar information...
http://jniolon.clubfte.com/driveline...nephasing.html
Old May 18, 2006 | 05:26 PM
Ford_Six's Avatar
Ford_Six
Depending on how much you lower it, you don't want to wind up with a zero angle on both u-joints. If you do, the joints will eventually seize, and spit the shaft out when the angle does change going over a bump or loading the truck with any weight.
Old May 19, 2006 | 01:01 PM
SmokeyBear31's Avatar
SmokeyBear31
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
this should clear any questions.
