Sponsored by: Real Truck
NEW MPG thread
Old May 19, 2006 | 03:04 PM
bigblack02's Avatar
bigblack02
Originally Posted by highboy390fe
2000 f250 regular cab lariat
60,500 miles
5 speed
5.4, 4.10 gears
305/70/16
I just bought it havent had a full tank through it yet, but i was wondering what everyone else runs for a rpm at 70, i am running close to 2400 rpms in overdrive. i was wondering if this is normal or what everyone else was running at. Thanks
that can't be right... 70 with a 32.8" tall tire with 4.10's and a .72 final gear - you should be cruising @ 2100-2150rpms unless you have 4.56's then your right where you should be.
Old May 19, 2006 | 04:39 PM
biglawndog's Avatar
biglawndog
2006 F250 SD SC LB
5.4
3100 miles
Stock 245's
10 MPG is the best so far.
If it doesn't get better I may go diesel
Old May 19, 2006 | 05:54 PM
estimator's Avatar
estimator
1999 f250 sd 3.73, auto, long box, sc, 235 tires
65mph at 2050 rpm on cruise, just myself and another 150 lbs
recently 17mpg(american ) or 20.7 canadian, no wind
I have had up to 22 canadian or 18 american on the highway
Old May 19, 2006 | 07:46 PM
97F250LD's Avatar
97F250LD
I have a 2003 F250SD extended cab, short bed, 5.4, 2wd, 3.73, 265/75/16, drive both highway and city everyday and I get 14.5 to 15 mpg, most of the time i have a soft foot but still lay into it every once and a while, have not modifed it yet, but will keep you posted when I do. Hope this helps, Michael
Old May 20, 2006 | 03:19 PM
ReAX's Avatar
ReAX
Updated again. Please look it over, play with it.
Old May 22, 2006 | 09:32 AM
highboy390fe's Avatar
highboy390fe
I have the 4.10's and i founf out my speedo is a little off its more like 2300rpms at 70.
