Offroad & 4x4
Offroad Carnage
Old May 30, 2006 | 09:34 PM
  #31
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
good lord sounds like fun
Old May 31, 2006 | 12:58 AM
  #32
1970Custom's Avatar
1970Custom
I don't break stuff, I'm too poor to go wheeling.
Old Jun 1, 2006 | 05:14 PM
  #33
slash31938's Avatar
slash31938
i mangled the rear slip yoke on my 78 bronco... the PO thought that needle bearings in a U-joint were unnecesary, or thy just turned themselves to metal dust. the u joint lost two of its caps and just reamed the **** out of the slip yoke, and cracked one side of it.
and i broke a cast alluminum 1st gear shift fork in a 2wd dodge playing in a wet field.... im so X7R3M3
Old Jun 3, 2006 | 01:04 AM
  #34
A_G's Avatar
A_G
i dented in the whole right side of my pickup...the first day i got it.
today. i went down a ATV trail...i didnt know it tho...i ended up getting a dent in the right fender. cracked mirror. and a scratch across the hood.
Old Jun 3, 2006 | 03:24 PM
  #35
B-one's Avatar
B-one
wheel bearing went kaput, and my eb tierods dont fit f150 knuckles. lol
Old Jun 3, 2006 | 05:47 PM
  #36
JeremyH's Avatar
JeremyH
Originally Posted by 1bad73bronco
Damn...that was a nice looking FSJ.
Old Jun 4, 2006 | 10:17 PM
  #37
RotGrubestier44's Avatar
RotGrubestier44
On one weekend, with my 94 F-150 completely stock except for a set of 32x11.50R15 Cooper Discoverer M/Ts I managed to break the passenger side coil spring and one of the leaf springs on the same side. I also cracked both radius arm mounts, ruined all 4 ball joints, ripped off my exhaust, ruined all 4 shocks, stressed out my M5OD (it whines alot now), damaged one of the tire's sidewall and had a U-Joint go bad. Needless to say I had alot of fun that weekend, and most all the stuff that broke/ went bad is getting replaced by a lift kit here in aboot 2 weeks.
Old Jun 9, 2006 | 06:55 PM
  #38
Mike12pt's Avatar
Mike12pt
95 F-150, Cracked main crossmember, wheel bearing blew on the way home taking out hub. Replaced engine because of sand. No more sand, I think I'll just stick to mud and not where the big dogs go (I only have 6" lift, 35" tires, 4:56 gears, posi in back, open in front).
Old Jun 10, 2006 | 07:55 AM
  #39
KubotaOrange76
you crack the crossmember in front of the engine?
Old Jun 10, 2006 | 12:43 PM
  #40
Mike12pt's Avatar
Mike12pt
The big crossmember holding the engine. I had it welded, but the welds broke and then I had to reinforce with 1/4" steel plates in addition to more welds. Seems to be holding up ok.
Old Jun 11, 2006 | 08:05 PM
  #41
KubotaOrange76
sounds familiar
i have some new carnage, ring gear bolts backed out in my sterling, one broke off and poked a hole in my diff cover....good excuse to reinforce it with 1/4 plate
Old Jun 13, 2006 | 03:52 AM
  #42
1970Custom's Avatar
1970Custom
I've never needed an excuse to re-enforce something, I usually do it before something breaks.
Old Jun 13, 2006 | 05:39 PM
  #43
KubotaOrange76
let me rewoard, how bout it makes me have to get off my butt and doit
Old Jun 13, 2006 | 09:42 PM
  #44
derherr65's Avatar
derherr65
Originally Posted by bhodgin
not me im suckin gas and haulin...
Amen! I live by the theory of "If your truck can't take a rice burner in the 1/4 mile, then you need a bigger engine." What's 11mpg when you can embarrass Toyota, Datsun, Nissan, and Honda owners.
Old Jun 13, 2006 | 10:38 PM
  #45
Thomsen's Avatar
Thomsen
umm, I have probably totaled my rig to most peoples standards more than 5 times, but to some it looks priceless.
