security light stays on - does not disable ignition
Old May 16, 2006 | 09:09 PM
19ranger97's Avatar
19ranger97
ford ranger 1997 - 3L - manual tran
as doors and windows are manual, only disables ignition. signals via horn.
the little blinking security light stays on when ignition is off and clicking on the remote does nothing (remotes are fine).
can find nothing on ignition kill system. only data is box that remotes came in say AutoMate am2.
Old May 16, 2006 | 09:19 PM
RangerPilot's Avatar
RangerPilot
There was a thread a while back about something concerning the security light. I believe it had to do with the light being a dummy light, designed just to worry a theif enough to deter him from trying to break in.
I know some other alarms do nothing for locking the ignition, just doors and setting the alarm.
RP
Zach
Old May 17, 2006 | 01:52 AM
19ranger97's Avatar
19ranger97
this light is for a real ignition disable. not a dummy. does anyone know how this system works and where it is located???
tnx in advance
Old May 17, 2006 | 02:50 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The flashing dash light on a PATS equipped vehicle is NOT a dummy light installed for ornamental purposes or the like, it indictes that the PATS system is functioning. Operating the remote will not affect the dash light that indicates PATS is enabled; PATS is an ignition disabling system and not a *traditional* alarm system. I could explain a bit about how the system works, but out of curiosity, what are you trying to do with the PATS system and why might the module location be of interest? Are you having problems with a PATS system and if so, specifically what are the problems?
Old May 17, 2006 | 11:37 AM
19ranger97's Avatar
19ranger97
CowboyBilly9Mile and all others... the PATS STOPPED WORKING and I need to know how to fix it.
Old May 17, 2006 | 12:50 PM
reddog99's Avatar
reddog99
What you seem to be describing is a correctly functioning system....
Pat
Old May 17, 2006 | 01:19 PM
CowboyBilly9Mile
More info on the vehicle situation (ie, symptoms) is needed. What happens when you try to start it? Does it crank? Spark? Fuel? Reddog correctly noted that your PATS, from what you have described, *appears* to be working correctly. How did you diagnose a PATS failure?
Old May 17, 2006 | 02:36 PM
Dave257's Avatar
Dave257
I'm not sure he is talking about a patts system. I think It only came on vehicles with Locks and windows. The reference to "AutomMate am2" sounds like an aftermarket system of some sort. We need some more info...
Dave
Old Oct 3, 2006 | 02:14 AM
DriverDave4q's Avatar
DriverDave4q
The Ranger didn't start to use PATS until 1999. This must be an aftermarket alarm
tim051
Aug 7, 2013 05:38 PM
Ranger1F150
Escape & Escape Hybrid
Dec 21, 2009 05:52 AM
mikewrt
Electrical Systems/Wiring
Sep 7, 2004 08:01 PM
