Another mileage UP
Old May 16, 2006 | 08:55 PM
Medic 66's Avatar
Medic 66
Another mileage UP
Just thought I would post this: More than a 1.0 mpg gain after the following:
*Switch back from 5w40 to 15w40
*Reset computer
*Switched to DK
Got cheap deisel tonight so I figured i would calculate real fast (math by hand that is) and all stop and go city driving was 17 mpg with a stock unit. Old mpg's was low 15's ish.
Later Taters!
Old May 16, 2006 | 09:10 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
what brand of oil were you running before and after the change?
Old May 16, 2006 | 10:13 PM
Medic 66's Avatar
Medic 66
Before was the 5w40 Rotella Synthetic........now is the Rotella 15w40
Old May 16, 2006 | 10:47 PM
SSGG's Avatar
SSGG
I did not believe that oil could make that difference either when my mechanic suggested it...but it did. Now using Rotella 15w 40.
Wes
Old May 17, 2006 | 06:14 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I've always believed in high quality, high dollar oil but would have thought it would have gone the other way with the synthetic producing better results. If you are to believe half of the propaganda put out by Madison Ave. I just tried the new Castrol 15-40 for the first time after using Rotella from day one.
Old May 17, 2006 | 06:26 AM
rmilchman's Avatar
rmilchman
Restting the computer is what increased your milage. Anytime I change the program I'm running my mileage increases. After a couple of tanks (computer learning) my mileage always goes back.
Old May 17, 2006 | 07:04 AM
PSNut's Avatar
PSNut
It's a fact that clean oil can improve your mileage. That's why i run bypass filtering. I always run the same mileage. A proper dose of a good additive helps by adding lubricity,improving cetane and dealing with water.
Nut
Old May 17, 2006 | 07:07 AM
Markadeck's Avatar
Markadeck
What is the most widely used? I was additive shopping the other day and was completely clueless.
Old May 17, 2006 | 07:18 AM
PSNut's Avatar
PSNut
Diesel Kleen grey bottle at Wally World, IHC,Auto parts store....etc. Stanadyne Performance formula from Xtremediesel.com(sponsor)
Nut
Old May 17, 2006 | 07:25 AM
rmilchman's Avatar
rmilchman
I switched from Stanadyne to diesel kleen, because diesel kleen is easier to find (Wallmart).
Old May 17, 2006 | 10:00 AM
Medic 66's Avatar
Medic 66
Resetting it has never made a difference in the past. I think it was everything together.
Old May 17, 2006 | 10:13 AM
empiretc's Avatar
empiretc
One thing is for sure on my truck, Medic. It likes good old Rotella 15-40. And when I use DK she likes it even more. The last run I made was a 200 mile jog with dk in the tank and I made 24mpg. I had a nice tail wind and was doing ~68mph, 2k rpm on mine. I would use it in every tank, but dk is a little hard to find in my area.
Old May 17, 2006 | 10:18 AM
bhiggins's Avatar
bhiggins
will DK work with biodiesel??
Old May 17, 2006 | 10:23 AM
rmilchman's Avatar
rmilchman
I don't believe you are suppose to use anything wit bio. Bio on it's own is much more of a lubricant that diesel.
Old May 17, 2006 | 10:28 AM
Markadeck's Avatar
Markadeck
That's good mpg, getting in my neighborhood. If you were to try about 500 miles at 63 mph you will blow me away. Are you sure you topped the tank? All of my highway mpg reports are on trips from Charlotte to Buffalo, which takes you through what is the best the east of the Mississippi can offer for mountains. I see you are in Texas, where you have to search far and wide for a mole hill.
