engine
Old Apr 15, 2002 | 08:35 AM
sauerf100s's Avatar
sauerf100s
engine
Old Apr 19, 2002 | 11:02 PM
Seifferlein's Avatar
Seifferlein
Post engine
I have a 1969 Ford F100 with a 390 and three on the tree. Its probably one of the nicest trucks around, but lately I have not been to happy with it. When I go to start it in the morning when its cold it does not want to start, which is understandable. So I tap the gas a little, crank it, and it fires right up, but then it wants to shut off so I figure that I ought to give it a little gas but when I do it takes barely any in and then it makes a sound like it has a hairball and coughs gas back up. So I let off the gas and then it wants to stall out. After going through this a few times I getit running and can take it up to 2000rpm without a problem. I put it in reverse attempt to back out of the driveway and the only way I can get it to move without stalling is by taking it past 2000rpm and then releasing the clutch. It moves a few feet then starts coughing and wants to stall out again. Finally I get it out of the driveway and go to put it in first and have the same problem. Once I get going I drive about a mile down the rode, press in the clutch and the engine stalls out So I attempt to start it up and it cranks and cranks and cranks and I tap the gas and after about five minutes of pushing the starter as far as it will go without flooding the engine I get a slight spark and I give it gas and just barely get it going and it is set for the rest of my drive. I got really tired of this really fast and decided to fix it. I found every cylendar to have 120psi except one which had ninety.(not too big of a problem right?) So I tare off the front cover and the timing is right on. I rebuild and adjust the carb and replace all points and wires and stuff. I brought the idle up from the recommended 650rpm to about 850rpm. The idle adjustment alone made a slight difference along with the recent warm weather but if it were cold and I dropped the idle I would have the same problem. Also if I drive my truck for maybe five miles with speeds ranging from 25 to 55 and I stop go into a store for five to ten minutes and come back out, try to start my truck I crank and crank and it finally starts. It is not overheated. I put on a new feulpump also. Once I get my truck going it runs absolutely perfect. So the only thing I could think of was a vaccum leak somewhere. Could someone please give me some suggestions on how to fix this problem and maybe some ideas on adjusting the carb.
thank you very much,
Brad:
Old Apr 19, 2002 | 11:14 PM
Mil1ion's Avatar
Mil1ion
engine
[updated:LAST EDITED ON 20-Apr-02 AT 00:15 AM (EST)]
How old is that carb that's on it?
It sounds like the choke fast/idle circuit is out of adjustment.
*Possibly* the whole carb needs re-builing
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
Need to decode your 78 Truck data plate? click here
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven!
[/font]
Feel free to visit my website.
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color =red] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Apr 20, 2002 | 01:08 AM
TKONO's Avatar
TKONO
engine
look into the carb to see if it is drooling gas into the intake after you shut the engine off. Also, does it smoke when it is giving you all these troubles, and if so, what color?
John
Old Apr 20, 2002 | 07:04 AM
Seifferlein
engine
I am unsure if there is gas still flowing into the engine after it shuts of, but I will check it. I did completely rebuild the carb but since it did not fix the problem I bought a new one which did not fix the problem either. There is no smoke coming from the engine or tail pipes. if you have any more suggestions please post them.
thank you very much
brad
Old Apr 20, 2002 | 08:51 AM
BrettCox's Avatar
BrettCox
engine
It runs rough until it warms up right? have you checked your plugs to see if they are fouled?
Old Apr 20, 2002 | 01:35 PM
Seifferlein
engine
The spark plugs are not fouled out and if they were bad wouldnt there be signs of it even after I get it warmed up?
thanks
brad
Old Apr 20, 2002 | 03:38 PM
CRJ900's Avatar
CRJ900
engine
Double check timing. and your point gap. Sounds like thats your problem
Old Apr 20, 2002 | 04:45 PM
Ratsmoker's Avatar
Ratsmoker
engine
Replace your points. Mine just did the exact same thing you are describing. Its not the only possible thing that could cause the problem but its only 3 bucks.
Old Apr 20, 2002 | 04:48 PM
mk's Avatar
mk
Post engine
I think Dennis has the right idea. Next time it stalls out, run around and check to see if the choke plate is closed fully. Back off the choke a little if this is so.
Old Apr 20, 2002 | 05:56 PM
Seifferlein
Post engine
I am absolutely certain that my poblem is not elctrical because I just replaced all points and wires and stuff like that(and gapped them to specs and quadruple checked them). the choke plate is not closed when it stalls out. the choke only helps for the first time that i start and once it runs out of air and sounds like it is going to stall I open the choke a little and it still tries to stall. So I open even more and still it wants to stall. The only thing i can do is to open the choke all of the way and it sounds for a moment like it is going to run fine but then it starts to stall again. so I give it gas(not a whole lot) and it starts spitting it back up.
If you have any more suggestions please post them
thanks for all your replies,
brad
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
