1997 Explorer 4.0 check engine light
Old May 16, 2006 | 08:36 AM
hancockr's Avatar
hancockr
My son was passing by where I work this morning when his check engine light came on. I had him leave his truck and take mine while he went on to his classes and am going to run out at lunch to borrow a code sniffer at the auto parts store. Is there anywhere I can find a comprehensive listing of codes for this vehicle so I will know what they mean when I read them, instead of having to get the codes and come back to work to search for them? It would be nice, if I find out it is a part I need to replace, to be able to get it while I am at the store!
A quick once over did not give any hints. Engine temp, coolant level, oil pressure, performance, idle, etc. all seem normal.
Approx 60,000 miles on truck, we have had it since new.
Old May 16, 2006 | 09:41 AM
aquanaut20's Avatar
aquanaut20
http://www.obd-codes.com/faq/obd2-codes-explained.php
http://www.obd-codes.com/trouble_codes/index.php
http://www.obd-codes.com/trouble_codes/ford/index.php
Here are the codes, bur might be as simple as cleaning the MAF sensor, or tightening the gas cap
Old May 16, 2006 | 09:51 AM
hancockr's Avatar
hancockr
Thanks for the quick reply. Had forgotten about loose gas caps. Will check that. Is the MAF the air flow sensor downstream from the air cleaner assembly? If I need to, how do you clean it? Never needed to before.
Old May 16, 2006 | 10:51 AM
Backin72's Avatar
Backin72
Try this link.
http://tinyurl.com/fbbna
Seeing as my previous post got turfed, I had to make it a "tinyurl".
What a joke.
Old May 16, 2006 | 11:05 AM
hancockr's Avatar
hancockr
Thanks all. Checked gas cap before I drove to Murrays Auto parts. Seemed tight, but???? Code P0455, Gross evaporative emissions leak. Sounds like gas cap is the primary culprit to me. Cleared the code. Did not come back on on the way back to work. We'll give it a day or two now and see...
Old May 16, 2006 | 11:06 AM
hancockr's Avatar
hancockr
Checked gas cap before I drove to Murrays Auto parts. Seemed tight, but you never know???? Will have to see if he filled up this AM on his way to school... Only code P0455, Gross evaporative emissions leak. Sounds like gas cap is the primary culprit to me. Cleared the code. Did not come back on on the way back to work. We'll give it a day or two now and see...
Thanks all for your help/suggestions.
jamers
Apr 27, 2017 02:47 PM
fivo2fst4u
64
Aug 4, 2016 10:51 AM
HawaiianPSD
15
Jun 6, 2016 12:55 PM
CelticFox
16
Feb 21, 2016 06:31 PM
Sbroom
17
Nov 16, 2015 12:20 PM
