U joints going symptons?
Old May 16, 2006 | 08:30 AM
PSNut's Avatar
PSNut
Folks,
Can someone give me indications on symptons,especially early, of U joiints
going out. I think i may have a joint going bad. Got vibration at different speeds unless i let off the go pedal. Mild vibration is best description. 64k on truck.
Thanks
Nut
Old May 16, 2006 | 08:44 AM
Grunt0311's Avatar
Grunt0311
Originally Posted by PSNut
Folks,
Thanks
Nut
Nut,
Well, I can only speak from personal experience. If broken, you will hear the click, click, click, or when frozen up it will make that vibration. But it could also be tires out of balance. That is probably the cheapest and less time consuming fix, so I would have those checked first.
Hope this helps!
Bill
Old May 16, 2006 | 09:14 AM
PSNut's Avatar
PSNut
Thanks Bill! I thought about tire balance but it smoothes out when i let off the throttle.Hmmmm.
Old May 16, 2006 | 10:02 AM
Grunt0311's Avatar
Grunt0311
Nut,
After going through all the problems I have had in the last 2 weeks, the last thing I would want you to have to do is chase your tail like I have. I just know that if your tires are out of balance, they will do lots of goofy things which will make you do a lot of tail chasing! If it lets off when you go slower, it very well could be ujoints. Can you pinpoint where it is coming from? It could also be the rear end, or front hubs. Do you have WARN's? U joints are one of those things that are hard to test if there is a problem, unless they are so bad one of the caps have broken and is rattling around. If it makes you feel any better (it didnt help me much), if you change them and it is not it, atleast you have new ujoints !
Good luck
Bill
Old May 16, 2006 | 10:16 AM
PSNut's Avatar
PSNut
Can't pinpoint it's source. Feel vibration everywhere. Different from out of balance tires(which i've had on other vehicles). Starts at around 45mph and goes to 55mph then smoothes till 69mph then smoothes till about 73mph. In the bad zones if i left off the gas to pull power from the drive train it smooths out like glass. Seems to be getting worse. My thoughts are: U joints, T/C , rear end
, tranny....don't know yet. Another learning experience. I'm a troubleshooter by trade(electronics).This truck has been a good learning experience.
Old May 16, 2006 | 10:25 AM
Grunt0311's Avatar
Grunt0311
Up until the last week, I thought I was a good trouble shooter. But after spending 40hrs under my truck, and about $600 in parts, I am starting to second guess myself, lol!
Old May 16, 2006 | 10:40 AM
roaky81's Avatar
roaky81
What I've done in the past is to place the rearend on jackstands and put the tranny in neutral. Now you can rotate the drive shaft while trying to move the yokes side to side to find any free-play. Also look for grease coming out of one or more of the bearing cups. If everything is real solid and pretty clean (always try to clean off excess when doing grease jobs), then I'd look else where.
Old May 16, 2006 | 10:44 AM
cgl's Avatar
cgl
Sounds just like my thread here...
https://www.ford-trucks.com/forums/s...d.php?t=482882
My U-Joints appeared ok, it was the CV joint in the driveline (it's actually part of the transfer case yoke) giving me my vibration...
Old May 16, 2006 | 10:46 AM
Pocket's Avatar
Pocket
Depends on which u-joints are going out. My father just replaced his rear u-joint, and we found it by a broken bearing cup. His symptoms were vibrations above 70 mph only, and got much worse as he increased speed. I've noticed recently that I have what I can best describe as slack in my driveline and a slight takeoff vibration. I've checked underneath and my front u-joint out of the transfer case is leaking from the bearing cup. Once I am moving though I have no vibrations at all. So your symptoms might vary depending on how bad the u-joint is and which one is failing.
Roaky has good advice. Check very carefully as driveline problems are sometimes hard to pinpoint sometimes.
Old May 16, 2006 | 12:05 PM
Grunt0311's Avatar
Grunt0311
The only thing I would add is that if you have a ujoint froze up, there wont be any play, and no necessarily any grease showing.
Old May 16, 2006 | 12:15 PM
sc93f's Avatar
sc93f
It's minimal effort to unbolt the U-joint from the rear axle and see what it feels like. Should be fairly easy to unbolt and feel the CV from the T-case. At least as a starting point.
Old May 16, 2006 | 12:30 PM
PSNut's Avatar
PSNut
WOW guys! ...thanks for all the great info. Will have to check into this stuff.
nut
Old May 16, 2006 | 02:10 PM
Kwikkordead's Avatar
Kwikkordead
Another thing to pay attention to is the frequency of the vibration. Is it tire speed? Or 4 times that? Making it driveline speed.
Old May 16, 2006 | 02:28 PM
turbostroke's Avatar
turbostroke
Folks,
Thanks
Nut
Hey PSNut,
I think you are on the right trail in your assessment of a bad U-joint! Classis symptom is the one you describe with the vibration but the second classic symptom as mentioned above is "slack" in your driveline. The best way to explain this is if you are at a dead stop or slightly moving (as in bumper -to-bumper traffic) when you hit the accelerator there will be a delayed reaction (maybe a second or two) in the driveline. Overtime you tend not to notice this, as it happens gradually, but after the new U-joints you wont believe it was that sloppy. When I had some work done on my truck a couple of weeks ago I also had all 3 U-joints on the rear driveline replaced. I would post part #'s but they are different depending on wheelbase dimensions and other factors so not all #'s would be the same for each of us. Mine were actually the same part # for all three u-joints! While you have to remove part of the driveline anyhow you might as well lower your carrier bearing (once this is loose the whole assembly comes off and you can do it on the bench), disconnect at transfer case and rearend and do all three at the same time so you are not guessing which one is bad. As already stated a bad u-joint doesn't automatically show any exterior sign of being bad. Hope this helps.
Old May 16, 2006 | 03:51 PM
PSNut's Avatar
PSNut
More to think about.... I did some searching on u joints. Are u joints pretty easy to replace? Never done any till now. My Helm service manual should help. Got to get under my truck again.
Nut
