melling HV pump?
Old May 16, 2006 | 01:02 AM
ford390gashog's Avatar
ford390gashog
melling HV pump?
i bought a new melling HV pump to go in the 76 ford truck i just got , the truck hasbad oil pressure and the stock pump is very worn so it is not pumping well. my question is the new pump came with a high pressure spring. should i use it? the engine has about 246k on it and runs well but has 10 psi at 700 rpm and tops out at 35 psi at 3500 rpm. would the high pressure spring cause any damage?
Old May 16, 2006 | 01:28 PM
dinosaurfan's Avatar
dinosaurfan
M57hv
f390gh, you'll be fine with the higher pressure spring. What will happen is the bypass will open less often than if the pressure was lower. And if you have lots of clearance on the bearings, the bypass may not open at all. I have a 390 with .0035 on the mains and .003 on the rods and am running the M57 HV pump, the engine was built with all used parts. At idle when warm I have 20~25 lbs, with a max of 55 at 5K. I spent 250$ on the whole engine and it has been just fine for almost ten years now. DF @ work on lunch
Old May 16, 2006 | 05:56 PM
ford390gashog
how hard is it to install the spring? the directions are not very good.
Old May 16, 2006 | 06:37 PM
rusty70f100's Avatar
rusty70f100
I wouldn't bother with the high pressure spring. All it'll do in that motor is increase cold oil pressure and high rpm oil pressure. It wont do a thing for idle oil pressure, that's more a function of volume. The fact that it's a high volume oil pump will help a lot more than the spring.
You could put it in; I dont think it would hurt anything, but I wouldn't waste the time. The stock spring should provide plenty of pressure for any motor. What you're after with that motor is volume, and you've already got that in the high volume oil pump.
Old May 16, 2006 | 09:40 PM
ford390gashog
thanks kurt,
thats one less thing i have to mess with. i figured it would only help at cold starts and at high rpm.
351WTF
Jul 22, 2012 12:16 AM
blisstruck
Mar 21, 2012 02:37 PM
tyminski
Jul 23, 2002 12:31 PM
winfordr
Aug 31, 2001 10:50 PM
Art
Dec 21, 1999 05:33 PM
