1978 - 1996 Big Bronco
tire clearence
Old May 15, 2006 | 09:23 PM
96eddie5.8's Avatar
96eddie5.8
tire clearence
ok, so the FTE Faqs say for 35 inch tires you need a six inch lift. off-road . com says 4" for 35 tires and 2" for 33s... anyone run 35s with a 4 inch lift? whats the rub like?
Old May 16, 2006 | 12:41 AM
greystreak92's Avatar
greystreak92
The FAQ info is for zero rub at full steering lock and full suspension compression. So with the wheel hard-over and at least one front spring fully compressed, the tire at that wheel will not rub anything.
Old May 16, 2006 | 04:30 AM
MatthewC's Avatar
MatthewC
35" tires and 4" lift you will need to either shim your bumper forward, or trim it.
Old May 16, 2006 | 05:17 PM
helirich's Avatar
helirich
You will also rub sometimes on uneven roads (offroad) while turning. But I ran that combination on an 88' for alot of years without much trouble. I did alot more hard wheeling than also.
