Sponsored by: Real Truck
cab lights
Old May 15, 2006 | 08:03 PM
peter88's Avatar
peter88
cab lights
Just bought a 2003 250 sd. It has these 5 orange lights mounted to the roof of the cab , like you might see on a tow truck or some commercial vehicle. Is this some of significance ? Are they a Ford item or an aftermarket add-on? Any help appreciated.
Old May 15, 2006 | 08:21 PM
FoMoCo05's Avatar
FoMoCo05
Could be either one.They say they are for better visibility to on-coming traffic. My 05 has them which I didnt care either way but I think thay are cool.
Old May 15, 2006 | 08:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
There is a LEGAL reason for them.
If the vehicle and any trailer exceeds 80" in width, you need 'em. I think DRW's have to have them. I'm not sure about requiring them past a certain height.
Otherwise, they are just for looks.
Either way, no problems. And no arguments about it guys, OK? Keep it technical.
Old May 15, 2006 | 08:58 PM
Neil's Avatar
Neil
They are optional equipment on a F250, no reason for them to be there other that whoever ordered the truck wanted cab lights.
If you had purchased a 1 ton with dual wheels, or a F450 & up, then the lights are required by federal and some state regulations.
Old May 15, 2006 | 10:23 PM
Headviking's Avatar
Headviking
My 350 Lariat DRW has them. As I remember, on the XLT it was an option. Up here in Canada anyway. John
Old May 15, 2006 | 10:43 PM
Vinford's Avatar
Vinford
I wish my 02 had them.
Im going to get some.
Old May 15, 2006 | 10:54 PM
Deluxe05's Avatar
Deluxe05
Part of the intent of the law behind cab clearance lights is so that your fellow motorists will be able to identify your direction of travel (amber lights indicate the vehicle is facing towards you - red lights indicate the vehicle is facing away from you), and approximate distance & position on the roadway when they see you.
Duallies have marker lights around their extended wheel wells for the same reasons.
Old May 15, 2006 | 11:37 PM
jonredbird's Avatar
jonredbird
Matter of taste.....getting some put on my new '06 this week. You can get clear, smoked, etc....but I like the amber.
Old May 16, 2006 | 04:59 AM
ryaneverk2's Avatar
ryaneverk2
The lights are required on vehicles over 80" in width, such as duallies. The National Highway Traffic Safety Administration calls them "conspicuity lights," since they're supposed to make a truck conspicuous or easy to see and stand out for safety's sake.
The three in the center are the ID portion (same as the three on the rear between the tailgate and bumper), and the outer two are merely clearance lights. So, on duallies they're required, and on SRW trucks, they're just for looks.
Old May 16, 2006 | 07:09 AM
BFR250SD's Avatar
BFR250SD
Mr ryaneverk2 is correct.
Old May 16, 2006 | 07:55 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I ordered them on my '06 F-250, I just like the look of them.
Old May 16, 2006 | 08:55 AM
ag-ford-4x4's Avatar
ag-ford-4x4
i had the dealer add them to my 05 F-250....i told my wife i was not buying a diesel pickup without clearance lights....period.
Old May 16, 2006 | 09:28 AM
krewat's Avatar
krewat
Common misconception.
Clearance lights are required if anything about the vehicle is over 80" wide too...
So, you may see a SRW with clearance lights, but they aren't just for looks. The trailer that thing tows is 80" wide or bigger
Or, you have a drop-in camper that's 80" or wider, etc etc.
Old May 16, 2006 | 01:56 PM
ryaneverk2's Avatar
ryaneverk2
I was just referring to the truck itself, as it comes from the factory (no trailers attached ). Sure there are some SRW trucks that require them like Hummers but our trucks don't.
Actually I thought that only the thing that's over 80" requires them, so if you're towing a large trailer with a car, the car doesn't require them, but the trailer does. Or say you put a camper on your SRW Superduty, the camper requires them but the truck does not. I guess if that's not right I need to do a little research!
Old May 16, 2006 | 02:28 PM
krewat's Avatar
krewat
The way I remember it, the last time we went round-and-round about this, is:
If ANY part of the vehicle, tractor OR trailer is 80" or wider, the tractor needs clearance lights. The trailer does need "marker" lights or some such.... but pretty sure the tractor needs them no matter what if the trailer is 80" or more.
There should be a backyard lawyer visiting this soon
