2000 X Drive Shaft "Thump"
Old May 15, 2006 | 07:21 PM
bucks4fun's Avatar
bucks4fun
Hi folks. First timer here and I sure could use some help with the "thump" I'm getting in the rear drive shaft in my 2000 X. It happens when I come to a complete stop and the rear end "settles". I get a pronounced "thump" in the rear. If I put the truck in neutral while rolling and then stop it makes no sound at all....so I'm convinced it's in the drive-line. I have the 2-piece drive shaft that is basically on pieced sleeved inside the other and there's a rubber boot covering the intersection. There is some "play" in the booted section that the dealer says is normal, but I suspect that's where the thump is coming from. Anyone ever dealt with this? Thanks in advance for any feedback!
Old May 15, 2006 | 07:34 PM
cficare's Avatar
cficare
Try coming to a slow gradual stop in gear (versus your everyday traffic-light-style of stop) and see if you hear it. Your splined shaft inside the driveshaft (there's usually a rubber boot around it) may need some grease. They're known to have been sparsely greased by FOMOCO.
Oops! Where are my manners? WELCOME to FTE!
Old May 16, 2006 | 03:46 PM
SmokinJohn's Avatar
SmokinJohn
Yeah, the Ford tech took care of that exact thump on my 2000 for no charge when I took it in to get the fluids replaced after purchasing it. That was cool.
Old May 17, 2006 | 05:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bucks4fun to Ford Truck Enthusiasts!
…..See you on the boards.
Old May 17, 2006 | 09:34 AM
Downriver Thunder's Avatar
Downriver Thunder
Did he say what was making the thump?
Old May 18, 2006 | 04:28 PM
SmokinJohn's Avatar
SmokinJohn
Sorry about not being clear there. This quote below sounds like exactly what he said to me.
