swap a 6.9 for a powerstroke?
I was wandering if anyone had swaped a 6.9 for a powerstroke. First the details, Ihave a 86 ford f 250 with a manual trans. I found an entire doner truck a 97 350 but it has an auto trans. I wanderd if the bell housings would be the same(bolt pattern) so I could just get a new fly whel and starter and through it thogether. The next thing I was wandering was would the powerstroke fit into the 6.9 motor mounts on the frame. I allready know I woud need the computor and wiring harnesses. Any help would be apreceated. Thanks in advance.
Whats wrong with the 97 get in an accident or something? That would be a project in a half, you would have to save all the wiring, computers, relays sensors ect you kno that tho lol, you also prob need all the interor parts. The driveshafts would match the rear ens i think, may have to be cut idk. Idk if the mounts would be the same. To me an 86 truck isnt worth all the trouble of that and isnt worth all the time and money, unless that 97 is totaled why not just drive that, i kno i would over my 89 f-350.
If it were an F series it would bolt right in, transmission will bolt up, flywheel will bolt up.
But that is the easy part.
You will be running wires for a while, and the E series wiring harness will not fit your truck. I would say you will probably have a month or so doing the wiring.
Remember, your 86 has throttle pedal that hooks to a cable that hooks to the IP.
The Power Stroke throttle hooks to wires that hook to the computer that hooks to more wires that hook to the engine.
I considered it in my 86, I am a master electrician. I bought another 6.9 to install in my truck, I wanted to drive it this year again.
Even if you had a 97 F series donor vehicle, you are going to have to change a lot of stuff. Dash, complete wiring harness that will not fit the 86 right, rear axle, pedals, lots of mods to the fuel system lines, and more that I am not thinking of right now.
It has been done before, but it will be a lot of work.
And until you do a bunch of work to the 97 Power Stroke, you can make an 86 6.9 outrun it a lot easier and cheaper.
Thats kind of what I was afraid you guys would say. I didnt think of things like changing the rear end out becase of the speed sensor. ok how about this route then. Sice I have the powerstroke would it be possible to run that block and put the heads off a na 7.3 and add the turbo and intake. I got the truck for almost nothing I have to not be abel to do any thing with it.(the van that is)Or would it be easer yet to just swap in the turbo.I know I would still have some wireing to do but not nearly as bad. what do you think
Nope the 7.3 uses a completly different in jection system. The injectors are powered off of a high preasure oil pump and they are not the same in any way shape or form... I dont think you will be able to swap the turbo in either because that is controled by the computer. whats up with the speed sensor in the rear end? maybe an abs sensor but the speed sensor as far as i kn ow is not in the rear end there is a sensor that runs off the speedo cable.
