Tranny problems HELP ME, PLEASE!!!!1
Old May 15, 2006 | 10:20 AM
Todd525's Avatar
Todd525
I have a obs psd f350 dually. I have owned it three years. I have a tranny problem.
When cold, everything is close to normal. it doesnt seem to slip, but not real sure. I am sort of a motor nut, but thats in jetskis, motorcycles quads, and gas motors. No tranny.
When warm under normal conditions, if I am cruising down the highway, in OD, and I give it a little gas just to speed up, the rpms jump about 200 or so. I should not say jump, its more like "slide". It doesnt do this when cold. It is not kicking down. It feels like the lockup is bad, but I dont know if thats the converter or the tranny. It ticks me off too. With my edge data stream, I see temps in the 180 to 200 range now. I know its high, and its due to the slip.
So the question is, tranny or converter?
I dont have a lot of money now, racing season being here, etc...
I knew I should not have pulled that broke down semi back to the farm, my truck is old, but I love her.
All info is greatly appreciated.
Old May 15, 2006 | 10:33 AM
Todd525's Avatar
Todd525
Another thing that I wanted to ask, I can get a tranny out of a 99 DIRT cheap. Will that work in my OBS? Has anyone done this? I dont know if the tranny is different or if the computer runs it any differently, but I guess i should know that BEFORE i drop 500 bucks on it, RIGHT? LOL
Old May 15, 2006 | 11:59 AM
Casey's Avatar
Casey
That's the torque converter unlocking. It doesn't do that cold because the torque converter doesn't lock when it's cold. It's normal.
The only way to change it is to get a custom chip that changes how this is programmed in the computer.
Old May 15, 2006 | 12:09 PM
dave at BD Power's Avatar
dave at BD Power
Former Vendor
BD offers a Torque Loc which is a toggle switch to manually keep the convertor locked up, it works great on deceleration too and will release at about 20MPH.
Hope this helps
Old May 15, 2006 | 12:11 PM
Todd525's Avatar
Todd525
no man, this isnt normal, I mean when I just SLIGHTLY give it more gas, like enough to speed up 2 mph in 6 seconds, or coming up a overpass on the freeway. Its not normal. It wont hold rpm in cruise control on flat land, it slides up and down.
Old May 15, 2006 | 12:25 PM
1997F-350's Avatar
1997F-350
if i am not mistaking the 4r100 and e4od are interchangeable. shoot maybe a 99 tranny still was the e4od. i am no auto guy but that sounds like you have a bad convertor or clutches. hang out for a while i am sure someone who knows will come along.
Old May 15, 2006 | 12:43 PM
Todd525's Avatar
Todd525
well, from what I have learned, the 95 and 96 are the same, EVERYTHING else is different. The 97 is its own beast all together I guess. I really need to find someone that knows whats going on for sure. Just got off the phone with Ammco and I think they knew less than what i did.
Old May 15, 2006 | 01:33 PM
Phydeaux88's Avatar
Phydeaux88
It sounds like your TC may be the problem replace it with a heavy duty aftermarket and while you are at it do the tricumulator valve and sonex spring mod
Old May 15, 2006 | 01:58 PM
dave at BD Power
Former Vendor
Where are you?
Send me your zip code and I can see if we have any BD Dealers that are good with transmission diagnostics near you.
Old May 15, 2006 | 02:56 PM
Todd525's Avatar
Todd525
located in central ohio. 43302 just north of columbus
Old May 15, 2006 | 03:05 PM
dave at BD Power
Former Vendor
Thats great, Columbus Diesel Supply are large BD Distriutors and have a very knowledgeable staff.
Coulumbus Diesel Supply
Contact: Ben / Dave / Larry
Phone: 800 637 5253
Fax: (614) 445-8104
http://www.columbusdieselsupply.com
Old May 15, 2006 | 04:31 PM
Todd525's Avatar
Todd525
They do trannys and such there? You have a number for them? Sorry for the hassle...
Old May 15, 2006 | 05:03 PM
dave at BD Power
Former Vendor
Yes they do transmissions, I listed the number in my last post 800 637 5253
Old May 15, 2006 | 06:17 PM
Todd525's Avatar
Todd525
Your last post, umm about that. Its all your fault. I blame you. If you wouldnt have distracted me with the help that you gave me, I would have been able to look the extra inch and see the info. So see, you have no one to blame but yourself. LOL
Old May 15, 2006 | 07:24 PM
trike1946's Avatar
trike1946
The best thing is first check it on a computer. It does sound like a TC or clutch problem. But if you are going to pull it out, then do it all. Up grade the planet gears, heavy duty TC, sonnex etc. Also put in an "electronic systems eliminator". You can get it from Freeway transmissions.
I tried to switch parts from a 4r100 to my E4OD, but it doesn't work. You can make the E4OD just as good. Just don't skimp. Do it right.
