390 hard start
Old May 14, 2006 | 09:53 PM
stang30's Avatar
stang30
390 hard start
I just bought a 80 ford f250 that has had a 300 to a 390 swap i think the guy who rebuilt and installed this motor wasnt the best in his field if you know what i mean i have got everything fixed except a starting problem, it starts up fine when cold but after driving a while and shut it off will not restart unless you let it sit a while or jump start it not sure if its starter problem or alternator problem, i put new alternator, voltage regulator, battery and cables on it only thing else is starter or higher amp alternator was hoping that someone has had similar problem and had some advise thanks in advance
Old May 14, 2006 | 10:25 PM
Bear 45/70's Avatar
Bear 45/70
It's called a bad starter.
Old May 14, 2006 | 10:26 PM
ford390gashog's Avatar
ford390gashog
the starter is bad , but does it have headers? if so the starter is getting way to hot. or the timing could be way to far advanced causing it to kick back and not start.
