My truck did not come with the optional Tow Command feature, my question is can I purchase the OEM module and associated wiring and install this on my truck after the fact?? or am I just better off installing an after market brake controller, and what are some good brake controllers out there??
Trailer Brake Control
Part Number: 5C3Z-19H332-BA
MSRP: $505.67
Add the Integrated Electronic Trailer Brake Controller to any new 2005 F-250/350 Super Duty and provide the ability to assure smooth and effective trailer braking. The TBC powers the trailer's electric brakes with a proportional output based on the towing vehicle's brake pressure. Note: The Ford TBC can only be used with trailers that have electrically-actuated drum brakes (one t0 four axles) and not hydraulic surge or electric-over-hydraulic types.
Fits:
Ford Super Duty F-Series 2006 2005
Should be able to find the above info at this website; Enter your vehicle description first and then..... search on "trailer" or enter the above part number
Although that is what Ford SAYS, there are electric over hydraulic systems that will successfully work with Tow Command. Sensabrake and Carlisle are a couple of manufacturers that make them.
You may have a problem there. I visited that site and found that they had STOLEN my COPYRIGHTED material and posted it on their website as their own. I have notified their domain registrar and ISP.
