Electrical Problems?
Old May 14, 2006 | 04:46 PM
bobbyoshay's Avatar
bobbyoshay
Ive got a 05 screw and the power mirrors stopped working couple of weeks ago. I pulled the fuse that is located in the kick panel on the passenger side of the vehicle but it looked to be alright. I havent had much time to check other fuses or problems but today i tried to use 4 wheel drive and it wouldnt engage. I think that the these problems could be related but havent really dug into the problem too much. Any advice on how to troubleshoot these problems would be greatly appreciated. Thanks in advance!
Old May 15, 2006 | 10:42 AM
spiggy769's Avatar
spiggy769
Just for Your info...just because a fuse "Looks" okay...doesn't mean it is. I have seen many fuses that appear to be okay only to be bad...and this includes Glass fuses. About the only Accurate way to check to see if a fuse is good is by using a Ohm Meter/Continuity Checker. Another way is to take a known good fuse and try that in the assumed bad fuse location...just be sure to use at lease the same amperage and dont go pulling out a criticle fuse from another location that you will regret blowing.
Old May 15, 2006 | 01:43 PM
Ruckus's Avatar
Ruckus
I would suggest taking it to the nearest Ford dealership while still under warranty. Good Luck!
