no intake at all?
Old May 16, 2006 | 08:59 PM
7.3burnoutbuddy's Avatar
7.3burnoutbuddy
No effects to my knowledge. all that i've noticed is that it makes more noise and more importantly more power!
Old May 16, 2006 | 11:10 PM
Dave7.3's Avatar
Dave7.3
Well I don't wanta cut it and find it it was something important or anything. Sounds like a good power increase but just wanta check all options first. Kinda goes with the rule "measure twice, cut once"
Old May 17, 2006 | 01:21 AM
seanvicious's Avatar
seanvicious
i'm pretty sure the purpose of it is to dampen the noise. cutting it off makes the air flow better giving it more power, and makes it a little noisier under the hood at the same time.
correct me if i'm wrong on this someone...
Old May 17, 2006 | 10:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
For what it is worth, the E series engines don't have that mess in their air cleaner.
Sound control an cut the power back is all I can figure.
Serves no benifical purpose in the real world.
Just be careful when you cut it off, you don't want to cut through the lid.
Or stop by a salvage yard and see if you can find the lid off of a van air cleaner housing.
Old May 18, 2006 | 08:21 AM
pnose's Avatar
pnose
[QUOTE=Dave Sponaugle]For what it is worth, the E series engines don't have that mess in their air cleaner.
However they do have a much smaller hole in the bottom of the air cleaner sitting on the intake,which in my opinion rules out the soup bowl theory of swirling the air.As said above its for noise reduction.
Old May 18, 2006 | 12:01 PM
Dave7.3's Avatar
Dave7.3
I just had an idea, has anyone seen those commercials for those things that are supposed to swirl the air inside the intake? I bet you could make your own and get a little power gain out of it...sound possible?
Old May 18, 2006 | 01:52 PM
seanvicious
i've heard they were supposed to do quite a bit for 8 cylinders. they're only about $50 reguardless, and according to their policy, if they don't work you can send them back.
Old May 18, 2006 | 02:17 PM
Dave7.3's Avatar
Dave7.3
Can anyone PM me the site so I can research this? I know there are ALOT of cheap knock-offs so I wanta look into it
Old May 20, 2006 | 11:01 PM
KyleLight's Avatar
KyleLight
WOW!!! Maybe I Should take a pic of my intake and see what you think.......I guess mine has some kind of performance parts. My air cleaner does NOT look like that.......although its more of a HINDERANCE than performance.......mine is like a giant soup bowl....without a top........that collects rain water when it rains.....
Old May 21, 2006 | 06:02 AM
Dave Sponaugle
Dave7.3 I think those would not work right.
For what it is worth they also have a TAG, or turbo air guide for turbo engines that works exactly the oposite, straightens out the air flow for better performance.
I don't remember right now, but I think they were also in the 50 dollar range.
One swirls for better performance and air flow, one stops the swirl for better performance and air flow.
Make up my mind please.
Old May 21, 2006 | 03:32 PM
Dave7.3's Avatar
Dave7.3
I know of a few that are designed to swirl the air for performance...but I haven't seen one that straightens it out. The ones that swirl the air look like they can be easily made from a $5 sheet of metal thats why I was wondering about it.
Old May 30, 2006 | 08:19 PM
Dave7.3's Avatar
Dave7.3
Went to the local salvage yard today, found an air cleaner lid off a 6.9...It looks like it will fit on my 7.3 but I am asking is this the design I am after?
PS- The small valve on the lid is rusted, is this a bad sign and how do I clean it?
Old May 30, 2006 | 08:37 PM
  #28
seanvicious
that would be what it looks like with the soup bowl cut off.
Old May 30, 2006 | 09:06 PM
  #29
Dave7.3's Avatar
Dave7.3
how should I clean up the valve on the lid that is rusty?
Old May 30, 2006 | 11:10 PM
  #30
Dave Sponaugle
That is what you want, don't worry about the fitting.
Now I know where I left my truck keys laying, where do you live?
I don't remember sitting on that rock before.
