Transmission fluid change.
Old May 14, 2006 | 10:44 AM
Heavy460's Avatar
Heavy460
1988 F250 Custome,460 4x4 manuel transmission.
Sholuld i follow chiltons directions on how to change the transmission fluid and transfer case fluid?What fluid should i use?Should i use a treatment?No metal tags.I dont think the fluids have been changed for some time.I checked the transmission fluid level and a lot came pouring out red.Chiltons says it should be at the fill hole level.There is a black coating of dry oil near the drain plug on the transmission.I noticed shifting dose not get easy untill it warms up.50s and below temps take a little longer.Some times when iam in second or third gear it sounds like the 4x4 is sort of engaged,but its not.Thanks for any help.
Old May 14, 2006 | 12:59 PM
Beast12's Avatar
Beast12
Thread moved to Transmission and Transfer Case, etc. forum.
-Matt
Old May 14, 2006 | 05:17 PM
wickymustang's Avatar
wickymustang
Use what Ford says to in the tranny. The level is fine if you pulled the plug and some came running out. The stains by the drain are from dirt collecting on the residue from past changes that wasn't cleaned up. No need to treat a manual tranny for anything. The reason that shifting is hard at lower temps is due to the fluid being old and/or incorrect.
DieselDreamer
Dec 16, 2018 02:36 PM
brychar
6.4L Power Stroke Diesel
56
Jul 16, 2016 12:58 AM
rjrapp85
Nov 23, 2008 10:41 AM
BlueOvalLover
Oct 4, 2008 06:32 PM
amerimutt
1997 - 2003 F150
18
Dec 27, 2006 06:01 PM
