Brake problem
Old May 13, 2006 | 07:54 PM
1979f_100's Avatar
1979f_100
Brake problem
I have had brake problems with my truck since I bought it, four years ago now (wow I've had that thing for while ). I change the master cylinder two years ago, and the problems subsided for a good while. But slowly, it has greatly degraded in performance. It is so bad, that I have to put the pedal to the floor and it still takes about 30-40' to stop from 30mph. They won't even lock
I tried bleeding the brakes early, and that didn't help. I pulled the master cylinder cover off, and hit the brakes, and the front section spit fluid every time I hit the pedal. Any ideas why?
By the way, I do know my brake booster is going out .
Old May 13, 2006 | 08:07 PM
Mil1ion's Avatar
Mil1ion
Does this truck sit around a lot ?
The old saying: " use it or lose it" applies to the braking systems on these trucks
Old May 13, 2006 | 08:25 PM
havi's Avatar
havi
I'll have the Roast Duck
lol...ain't that the truth. Brake fluid breaks down over time as condensation takes over. If your pads and shoes are ok, then it could be stuck calipers or wheel cylinders, proportion valve, master cylinder, or damaged lines. Try rolling the truck with the engine off and apply the brakes. Is there any difference? brake booster only helps with the engine running.
Old May 15, 2006 | 05:27 PM
alcan60283's Avatar
alcan60283
sounds like the master cylinder is bad to me, classic signs there. Get a new unit instead of a reman one, thats helped me in the past. Seems like the reman units dont last very long. And yes, it does spray fluid from the front resovoir, mine does that too.
Old May 15, 2006 | 06:22 PM
stevstep's Avatar
stevstep
I Have A 78 4x4 With 35,s And My Brakes Suck I Have Replaced Master /power Boster Blead And Blead But No Luck Even Checked Block On Frame STILL DONT STOP VERY GOOD AND WONT LOCK UP IF YOU FIX YOURS PLESE LET ME KNOW THE FIX THANKS
CollinsCD
26
Dec 27, 2013 02:10 PM
mamatried
Oct 18, 2011 08:24 AM
fwerring
Aug 31, 2010 03:52 PM
hawk_eye
Jun 17, 2001 02:16 PM
