Sponsored by: Real Truck
trailer question
Old May 13, 2006 | 03:42 PM
birddog16's Avatar
birddog16
trailer question
I was wondering if anyone has tried hooking a duece and a half trailer to their super duty and if so how much work went in to converting the breaks?
Old May 13, 2006 | 04:59 PM
BFR250SD's Avatar
BFR250SD
What brakes are you wanting to convert??? If you're talking about using some sort of air brakes, then I hope you have an air brake endorsement on your license, otherwise you're looking at some fines.
I would think the easiest conversion would be to convert the trailer to either surge or electric. In this case, surge might be the easier switch.
Old May 13, 2006 | 05:17 PM
birddog16's Avatar
birddog16
the easiest and cheapest of course. I think you are right about the surge being the easiest since its already hyd system.
Old May 13, 2006 | 07:30 PM
mostoyzwinz's Avatar
mostoyzwinz
Pulling a 6,000 lb boat with surge breaks for the last several years and comparing it to a 4 place snowmobile trailer I have with electric breaks, convinced me electric is superior...beside the obvious adjustability.
Old May 13, 2006 | 10:37 PM
kimminau2's Avatar
kimminau2
I had a 14k equipment trailer once (and only once) that had surge brakes and it was awful. Went up a gravelly dirt road once, it was pretty steep, but it certainly wasn't extreme, anyways I had to stop, which was pretty easy since I was going up hill, but I did not intend to go backwards. The trailer had other ideas. At the time I had a 4x4 DRW and it didn't matter. Pulled me about 100 yards down the hill where the road took a turn and fortunately hit a bank and stopped the rig. If it had been an outside corner the little mishap would have had a much nastier ending. Had to unload the trailer right there to get going again. Now the brakes would not have given the truck anymore traction to get started up the hill again, but I would not have been going backwards out of control.
A week later I ditched that trailer and will NEVER have a trailer with surge brakes again.
Old May 13, 2006 | 11:12 PM
skinner00's Avatar
skinner00
i tow a 5500 lbs boat that has surge brakes, it is only 3 months old. i have had nothing but problems with the brakes on it. first they leaked, then fixed, then leaked, they replaced the entire unit, then they just didnt work. (like they didnt bleed the brakes) actually it is in the shop as we speak
Old May 13, 2006 | 11:25 PM
wmjoe1953's Avatar
wmjoe1953
Check your states laws governing airbrakes. In Oregon, you do not need a CDL to drive a semi, or any thing with air brakes, unless you register it as over 26,000 pounds, or it is for commercial use. Personally, I would go electric if you're converting, otherwise, I'd keep the air brakes.
okwaho1650
Jan 27, 2009 08:54 AM
BENG0924
16
Oct 17, 2008 04:20 PM
GeneStoner
All Things Towing
May 7, 2005 01:57 PM
tnscrew
1997 - 2003 F150
Jan 4, 2003 09:34 PM
Colinator
Apr 22, 2002 06:54 PM
