GPR on 99PSD Install ?'s
Old May 13, 2006 | 02:24 PM
Grunt0311's Avatar
Grunt0311
Okay, truck didnt want to start again this morning, so went to NAPA and bought new GPR part # GPR109. I am trying to install, but there are 2 relays, one in front that looks to be same size as what I bought, and one in the back a little smaller. So I am thinking one in front, but mounting holes are different. On the one currently on the truck, the holes are across from eachother at 12 & 6 oclock. On the GPR109 they are next to eachother at 3 & 6 oclock.
First, am I correct in assuming that the GRP is the relay in front, toward front of truck? And why are the mounting holes different?
Any quick replys are greatly appreciated as I want to get this in and be done with it.
Thanks
Bill
Old May 13, 2006 | 02:46 PM
Grunt0311's Avatar
Grunt0311
Okay, I am going to change my mind on which relay I think it is. The front one, (bigger one) has a wire to battery on one big post, and wire to ypipe on turbo on other big post. I am thinking this is not it. The smaller one towards firewall has battery wire on one post, and 2 wires coming off of other big post, one yellow and one brown, and going somewhere in harness towards valve covers. I am thinking this is the GPR. Am I correct?
Thanks
Bill
Old May 13, 2006 | 04:12 PM
stockernavstar's Avatar
stockernavstar
Gpr rear one. Aih front one. Bye the way do you have any pictures of the front relay? im reconntcting my aih to the relay and want to be sure of which terminal the power wire goes to.
Old May 13, 2006 | 04:35 PM
Grunt0311's Avatar
Grunt0311
Thanks Stocker, that is the one I changed. I dont have any pics, but power wire ie. battery wire goes to passenger side terminal. Hope that helps.
Thanks
Bill
Old May 13, 2006 | 05:04 PM
stockernavstar
no-problem
where does the one that goes to the y-pipe come off the relay?
Old May 13, 2006 | 11:07 PM
Grunt0311's Avatar
Grunt0311
that is on the relay forward of the GPR. It is on drivers side to that relay.
Good luck
Bill
suds
Nov 4, 2012 08:57 PM
TNT
Jan 18, 2012 02:48 AM
Csawyer
Apr 5, 2011 05:58 PM
bigbadwolfe
Feb 9, 2007 12:15 AM
PSNut
21
Feb 1, 2007 12:23 AM
