04 Front Suspension
Old May 13, 2006 | 10:50 AM
bigdavesohc's Avatar
bigdavesohc
Question 04 Front Suspension
I just figured out why they don't make lifts for the 04 and up ranger 4x4: there are no front springs. Does anyone know what it's called? It looks like a shock but larger. Is it a strut? Why did Ford do this?
Old May 13, 2006 | 12:10 PM
reddog99's Avatar
reddog99
There are no "coil" springs, but there are "torsion bar" springs. And there are lift kits on the market, but they cost an arm & a leg, which is why there aren't too many people that buy them...
Pat
Old May 14, 2006 | 07:39 AM
wendell borror's Avatar
wendell borror
Thats why most of us just crank our torson bars to level our trucks, and call it a day. A leveled ranger can run up to a 33" tall tire, thats plenty big on a ranger. I run run a 265/75-16, thats about a 32", and it looks , and works great. You can get lifts from RCD, and Dixon Bros, but there like 3,000$. Cranking the bars work just fine, and let you run all the tire you need on a ranger.
Old May 14, 2006 | 06:02 PM
soundwave's Avatar
soundwave
You've mentioned this before, Wendell. I have a 04 FX4 that I want to lift and Im, ahem,.."mechanicley challenged" Where could I go to have this done? If I get it done will this change anything to possibly void my warrenty? Thanks!
Old May 14, 2006 | 06:11 PM
RangerPilot's Avatar
RangerPilot
It won't blow your warranty unless it directly screws something up. If your suspension has truly factory problems, they aren't going to fix it because they can get away with blaming it on you. And cranking the torsion bars has a reputation for ruining the ride.
RP
Zach
Old May 15, 2006 | 03:30 AM
wendell borror
The fact is a ranger 4x4 doesn't ride all that smooth anyway, I can't tell the difference myself. I got mine done at a local tire and allignment shop, call a round untill you find one that will do it, even some auto repair shops will do it as well. This is not new tech, chevy, and dodge uses torson bars as well, there's even a torson bar lift out for chevy now that consists of new t-bars, and torson keys. You will need a new front end allignment anyway, so a shop that can do both is your best bet. I took my truck to ford last month to have my allignment checked while the warrenty is still good, and they never even noticed the t-bars were cranked, or at least didn't mention it.
Ingolf
Ford vs The Competition
322
Mar 31, 2005 05:10 PM
bbb1777
2004 - 2008 F150
Mar 3, 2005 11:46 AM
Saxon
Car/truck Buying Advice
Jun 18, 2004 05:47 PM
Power Stroke
Apr 20, 2004 07:04 PM
