Lift Help!!!!
Old May 13, 2006 | 12:34 AM
thetequilaworms's Avatar
thetequilaworms
Cool Lift Help!!!!
I Have A 98 Ranger. Single Cab. 2wd. Tryin To Get About A 2 Inch Lift. Whats The Cheapest Easiest Way To Go? Please Respond I Need Help Bad. Any Ideas???
Old May 13, 2006 | 03:15 AM
blitzen25bm's Avatar
blitzen25bm
you will probably get more help from the ranger section of the forum.
but ive read something about cranking up the torsion bars up front and getting some taller blocks for the back. shouldnt cost too much but i dont know how reliable that would make the truck.
Old May 13, 2006 | 06:25 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 13, 2006 | 10:43 AM
ondgas's Avatar
ondgas
I'm not sure what front suspension (on the 98) you have but there are many different types of lifts. Remember, you get what you pay for. You can lift it the cheap way and you will go thru tires like toilet paper. Retaining correct alignment is a factor on the front. If you have a coil spring front end then you can buy the spring and you'll need longer shocks and a longer pitman arm. If you have torsion front like the Edge then you can crank them up or add a lift spindel. Anytime you lift the front. You need to get an alignment and I'll bet money you'll need some cams. The rear is easy, you can add blocks and use longer u-bolts, replace leaf springs, or turn the shackles around if you have off-set shackles. This will give you about 2" of lift. You can also buy a 2" lift add a leaf for about 60.00 at ORW. Give us more details about your 98. Front suspension setup etc.... Coils or torsion, I-beam or a arms? That kinda thing. You can go mild to wild but you want to do it right so you can keep your front end aligned and the truck handling right.
Old May 14, 2006 | 07:44 AM
wendell borror's Avatar
wendell borror
The cheapest way is a 2" spring spacer lift from daystar for 96.00$
Old May 14, 2006 | 12:20 PM
RangerPilot's Avatar
RangerPilot
And a 2" lift in the front about levels the truck.
RP
Zach
Old May 14, 2006 | 03:33 PM
Help I M Stuck's Avatar
Help I M Stuck
coil spacers for the front and add a leafs for the rear.
Old May 15, 2006 | 03:39 AM
wendell borror
What size tire are you wanting to use, or are you just interested in lifting the truck?
