DOT warning----Ethanol/gas mixtures
Old May 12, 2006 | 04:00 PM
bigdmizer's Avatar
bigdmizer
Emergency Response Warning Issued for Gasoline-Alcohol Fuel Mixtures
Discuss
DOT is alerting emergency responders to appropriate emergency response guidance for responding to incidents involving fuel mixtures composed of ethanol and gasoline. The most common of these fuels is designated E85 (85% ethanol and 15% gasoline), recently has begun to be used in volume in the Midwest, primarily in the states of Illinois and Minnesota.
Fires involving E85 and other ethanol/alcohol mixtures containing more than 15% ethanol should be treated differently than traditional gasoline fires because these mixtures are polar/water miscible flammable liquids (they mix readily with water) and will degrade the effectiveness of fire-fighting foam which is not alcohol-resistant. For this reason, the Pipeline and Hazardous Materials Safety Administration recommends the use of alcohol-resistant foam to fight fires involving these fuel mixtures.
Old May 12, 2006 | 04:08 PM
Neb86's Avatar
Neb86
That could be a good thing to know even if you aren't a firefighter! What would a regular guy use? Dry-Chemical?
Old May 12, 2006 | 07:22 PM
OSin86's Avatar
OSin86
There's another added cost to using ethanol. Thanks for the info.
Old May 16, 2006 | 02:49 AM
jake00's Avatar
jake00
Interesting info
Old May 16, 2006 | 05:50 AM
Dungeon_Master's Avatar
Dungeon_Master
every car will be equipt with a bucket of flash powder like for asphalt roofs for fire fighting or a halon system.
Old May 16, 2006 | 11:29 PM
85e150's Avatar
85e150
More unintended but foreseeable consequences from bad public policy. This stuff is unsafe and will have cars stalled out everywhere by the time it is admitted that this is just a subsidy of ADM and others in the ag biz and does little or nothing to lead us towards energy independance.
So far, it just seems to be encouraging the owners of gas hogs to keep them running in hopes that ethanol will make 8mpg somehow acceptable in the near future.
quaddriver
23
Jun 9, 2014 10:50 PM
Greywolf
13
Apr 14, 2014 08:04 PM
tscryba
Nov 1, 2004 08:39 PM
Monsta
18
Oct 24, 2002 11:09 AM
