Headrests
Old May 12, 2006 | 10:23 AM
greymule's Avatar
greymule
Headrests
How do you REMOVE the headrest from an '05 regular cab with 40/20/40 cloth seats?
Old May 12, 2006 | 10:28 AM
derek4343's Avatar
derek4343
that was going to be my question so that you could turn them around for better comfort.
Old May 12, 2006 | 11:10 AM
greymule's Avatar
greymule
Headrests
I want the tailor to make some custom "throws" to protect the seats during everyday use. I just discovered how to remove the headrests but now the seatbelt may be a problem. To remove the headrest: There are two plastic rings that each post of the headrest slides threw. These "rings" are slightly larger than a quarter & about 3/8" thick. The left "ring" has a tab that protrudes upward from the inboard side of the ring. Press this tab to adjust the height of the headrest. The right ring has a little bit different looking tab on the outboard side of the ring. After adjusting the headrest to max height, depress both tabs & exert slight pressure upward on the headrest.
Old May 12, 2006 | 11:23 AM
Steve_Uzi's Avatar
Steve_Uzi
Custom "Throws" are available, I seen them in my Stylinconcepts catalog.
