Need Help with power windows
Old May 12, 2006 | 05:29 AM
bigmike09's Avatar
bigmike09
Well my porblem first started with my passenger side window working most of the time and then the driver window would not work butt the passenger would. It would kind of go back and forth.Now both windows do not go down. The motor in the driver side was replaced rescently and there was no slowing down on either of them when they would go down.I tried the passenger side switch thinking the driver side maybe bad but neither work.I do here a clicking noise though when i press the driv side switch.It seems like it is coming from under the dash.Is there some sort of relay for the switches or is it possible both motors went at the same time even though one is kinda new. Any help would be greatly appreciated and thank you in advance.I know yall are all the best.
Old May 12, 2006 | 10:01 PM
Franklin2's Avatar
Franklin2
I would go ahead and pull the door panels. Find the wires to the motors and with a voltmeter, read the voltage on the wires as you work the switches. If you are getting 12 volts to the motors, then the motors are probably bad.
