Just got my 2006 F250 XLT SC 4X4 Longbed(traded in the perfectly good 03 6.0)Been to the Tech Folder looking for this and can't find it?(Or just not looking in the right spot). How do you program the auto door locks to not lock when the vehicle is moving?? Already did the seat belt minder and going to do the key buzzer also. Doesn't say in owners manual or again I can't find it? TIA. And YES I have the 6.0 GRIN!!
Look on page 89 in your super duty manual.I've tried 8 times to get the seat belt reminder off and can't get it to work.
I have an 05, but would assume the steps were the same. I have disabled both the auto door lock function as well as the seat-belt ''chime" without any trouble. The door lock instructions are under the 'locks and security' section of the manual (page 88 on my 05 manual), and the seat belt instructions are under the 'seating and safety belt' section (page 105 on my 05).
I can't find anything related to the key buzzer. Not to say it isn't there, but I don't see it.
I unpluged the connector at the driver side seatbelt make sure you get the correct wire. No more reminder.
I'd be carefull with this one as the airbags are deployed at a different speed if the computer senses you have the seatbelt fastened or not. The two safety features are now interlinked...
I have a 2006 F350 Lariat, the way my manual says to turn of the belt dinger is wrong. This is how I did it after NUMEROUS failed attemps several other ways, and this way WORKED.
1. Head lights off, in PARK, parking brake engaged.
2. Turn key on and leave on, but do not start engine. All the dash lights will light up. Wait until seatbelt light goes off (1 minute).
3. Once seatbelt light goes off, plug in and unplug the seatbelt 9 times, ending with it unplugged. Here is the KEY, you need to unplug and plug 9 times as FAST AS YOU POSSIBLY CAN!!!
4. If done fast enough the seatbelt light will light up again, once the light is back on plug in and unplug the seatbelt 1 more time, ending unplugged. If done correctly the seatbelt light will FLASH a few times. Your done, Good LUCK
