autometer water temp guage?
Old May 11, 2006 | 10:41 AM
just2dune's Avatar
just2dune
A couple of people have commented on putting a autometer water temp guage in their trucks. Can somebody please tell me where you are putting the sender into the water system at( I am assuming you are using electrical guages not mechanical, correct)? Thanks for the help.
Old May 11, 2006 | 04:33 PM
MattB_1442's Avatar
MattB_1442
My electric Isspro gauge's sender went in a tap next to the upper radiator hose neck.
Old May 11, 2006 | 06:46 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Mechanical or electric, the sender can be located in a tap next to the thermostat. One plug is on top and another is on the side. I run mechanical, you can still get the temp with the key off.
Old May 11, 2006 | 06:59 PM
tjbeggs's Avatar
tjbeggs
i run electrical cause i don't want to chance coolant spraying my interior but yes the spot on the drivers side of the water pump is what i use cause the other one is used for my coolant filter.
Old May 11, 2006 | 10:50 PM
95_Dually's Avatar
95_Dually
Mechanical water temperature gauges do not have liquid inside the cab. There is a probe that sends a signal to the guage. Mechanical guages are usually more accurate than electric guages.
Old May 12, 2006 | 06:18 AM
tjbeggs's Avatar
tjbeggs
well i guess i learned something today. thanks for correcting my thinking.
